What are the limitations of the Ideal Gas Law?
The Ideal Gas Law (PV=nRT) assumes no intermolecular forces and negligible molecular volume, which holds true at low pressures where gas molecules are far apart. However, real gases deviate from ideal behavior under high pressure and low temperature, where intermolecular attractions and molecular volume become significant. In such cases, the Ideal Gas Law is not applicable, and the Van der Waals equation is recommended for more accurate calculations. Understanding these limitations is crucial for accurate gas behavior predictions. The Ideal Gas Law is most reliable under conditions of low pressure and high temperature.
optrix
I've been looking at Charles law, Boyles law, the Pressure law, and the Ideal gas law, PV=nRT. I want to know, what limitations are there to the gas law? Basically, why aren't real gasses ideal, when isn't it possible to use the ideal gas law, and in such a case, what else do you have to use instead? Thanks alot.
For ideal gases, we are assuming that there are no intermolecular forces and that the molecules themselves take up no volume. This is quite true at low pressures, because the spacing between the molecules is so large that they rarely collide. Also low pressure usually means that there is little of them or that the volume of the container is very large, so the space taken up by the actual molecules is negligible.
If you are dealing with cases where this is not true, you use the Van der Waals equation:
http://en.wikipedia.org/wiki/Van_der_Waals_equation
Thanks for the help!
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
