Ideal gas - percentage of fraction of molecules
The discussion revolves around solving a problem related to the Maxwell-Boltzmann distribution in the context of ideal gases. The original poster expresses confusion about the application of formulas for average, RMS, and most probable speeds, indicating a lack of derivation in their textbook. Participants suggest using equation 24.13 from the textbook, clarifying that dN/N represents the fraction of molecules within a specific speed range. The conversation concludes with guidance on selecting appropriate values for speed and range to apply in calculations. Overall, the thread emphasizes the importance of understanding the Maxwell-Boltzmann distribution for solving related problems.
Jahnavi
Honestly speaking , I have absolutely no idea about this problem .This doesn't happen often .In the KTG chapter , only definition and formula of Average , RMS and Most probable speeds is given .
This question is for an entrance exam which requires minimum application of calculus . So I am guessing there is a formula for this problem which I am unaware of .
Please help me solve this problem in a simple way .
Does your text not cover the Maxwell-Boltzmann distribution? Likely the Average , RMS and Most probable speed were derived using it.
Likes Jahnavi
You should know this does not count as an attempt -- so we're not allowed to help :rolleyes: .
Could it be you don't know what distribution you need for this ? i doubt that ...
Thanks @gneill for replying .
Please see the attached image from the textbook .As you can see nothing is derived .Only definitions and formula are given .
What about equation 24.13 at the bottom of the page?
Likes Jahnavi
OK . But I don't understand how to use this equation .
Do I need to find dN/N ? Or do I need to integrate this equation ? What will be the limits of N and v ?
Yes, dN/N would be the fraction of molecules with speeds between v and v+dv. Since the range of speeds given is pretty narrow, you should be able to get a pretty good approximation using dv ≅ Δv . Integration would give you an exact result, but the integral might be a bit tricky.
Likes Jahnavi
Should I go ahead with v = 323 and ∆v = 3 or v = 324 and ∆v = 2 ?
The latter.
Likes Jahnavi
Thank you gneill !
  • · Replies 17 ·
  • · Replies 69 ·
