Ideal Gas Carnot Cycle: Temperature and Entropy Analysis
The discussion focuses on the analysis of an ideal gas operating in a Carnot cycle, producing a net work of 400 joules per cycle. The maximum temperature during the cycle is 300 degrees Celsius, and the heat lost to a low-temperature bath is 600 joules. The temperature of the low-temperature bath (Tc) is calculated to be 70.8 degrees Celsius after correcting the heat transfer values. The change in entropy during the isothermal expansion is determined to be 1.75 joules/kelvin.
  • Understanding of the Carnot cycle and its efficiency formula
  • Knowledge of thermodynamic equations, particularly for work and heat transfer
  • Familiarity with entropy calculations in thermodynamics
  • Ability to convert temperatures from Celsius to Kelvin
  • Study the derivation and implications of the Carnot efficiency formula
  • Learn about the relationship between heat transfer and work in thermodynamic cycles
  • Explore advanced entropy concepts and their applications in thermodynamics
  • Investigate real-world applications of the Carnot cycle in heat engines
Students and professionals in thermodynamics, mechanical engineers, and anyone interested in the principles of heat engines and energy efficiency analysis.
scholio
an ideal gas operates in a carnot cycle so that it produces a net positive work of 400 joules per cycle. the maximum temperature during the cycle is 300 deg celsius and the heat lost to a low temperature bath is 600 joules per cycle.
a) what must be the temperature of the low temp bath?
b) what is the change in entropy of the gas during the isothermal expansion
Q = W = nRT ln (Vf/Vi) i don't think is use this equation as moles is not stated, volumes not given either
(entropy) deltaS = deltaQ/T
i am not sure what equations to use as i think i need to consider the entire cycle not just the individual isothermic/adiabatic expansions/contractions
will the same W equation from (a) be used in part (b) because in an isothermic expansion Q = W, but again moles and volume is not given?any help with which equation to use / approach is appreciated...
What is the carnot efficiency?
\eta = \frac{W}{Q_{h}}=1-\frac{T_{c}}{T_{h}}, W=work, Q=heat
where T_{c} and T_{h} are in absolute temperature, Kelvins. So you must convert from celsius to Kelvins.
For the second part, you are given that the heat is lost in the cold temperature so use the formula for entropy.
s = \frac{Q_{c}}{T_{c}}
using the equation you specified konthelion
do i sub in 400 for W, 600 for Qh, and 573K = 300 deg cels for Th, then do i solve for Tc?
so
400/600 = 1 -(Tc/573)
573(400/600) = 573 - Tc
-191 = -Tc
191K = Tc
so Tc = -82 deg celsius --> does it sound reasonable?
and for part b, finding the change in entropy of the isothermal expansion using the eq you provided
i got
s = Qc/Tc where Qc = 600joules, and Tc from part a was 191K so s = 6.59 joules/kelvin
reasonable?
cheers
Hi scholio,
so
The number for Qh does not look right to me. The problem said that was the heat transferred to the low temperatur bath, so 600 is Qc. How can you find Qh from what is given in the problem? Once you have that, I think the rest of it looks right.
i looked through my textbook and found this equation
W/Q_h = (Q_h - Q_c)/Q_h
where W = 400, and Q_c = 600, i solved for Q_h and got 1000
so subsituting 1000 into where i incorrectly entered 600, i solved for T_c and got 343.8K = 70.8 deg celsius
does that sound better now?
also i solved for the change in entropy and got deltaS = Q_c/T_c = 600/343.8 - 1.75 joules/kelvin
Looks correct to me.
  • · Replies 33 ·
