Identies: Sum And Difference, Double Angle hurry
The discussion revolves around proving the equality of the trigonometric identity sin 3x = (sin x)(3-4sin^2 x). Participants express uncertainty about the steps involved in manipulating the equation using trigonometric identities.
  • Participants explore the use of trigonometric identities such as sin(x+y) and sin(2x) to rewrite sin 3x. There are attempts to break down sin 3x into components and questions about the correctness of these steps.
Some participants have offered guidance on using specific identities, while others are working through the problem step by step. There is a mix of attempts to clarify the approach and check the correctness of each other's reasoning.
Participants are navigating through the problem without a complete consensus on the best approach, and there are indications of confusion regarding the application of identities and the manipulation of terms.
emohunter7
I need some help with these kind of problems. I don't clearly understand how to solve them. Here is one...PLEASE HELP!
sin 3x = (sin x)(3-4sin^2 x) PROVE THEY ARE EQUAL
You can use identities sin(x+y) = cos(x)sin(y) + sin(x)cos(y) and sin(2x) = 2sin(x)cos(x) for this. Merely write 3x slightly differently so that the use of these identities becomes more evident.
thank you...alright this one i am stuck on...i have been working on it for 10 minutes and can't come up with the answer.
2csc2x=(csc^2x)(tanx)
would the correct answer for my first problem be:
change sin3x to (sinx)(sin2x)
then change sin2x to 2sinxcosx
then change that to (2sinx)(2-2sinx)
then...i don't know...but am I on the right track??
This is incorrect. Put sin(3x) = sin(x + 2x) instead.
okay thank you I will try that
alright as my next step I put (sinx)(cos2x)+(sin2x)(cosx)...is this correct?
do I then change the cos's to sin's?
Yes. Perhaps you should attempt the entire problem and then post your solution instead of posting line by line.
sorry I just need to know where I'm messing up.
Okey, my first advice wasn't flawless because I didn't notice that you need the formula for cos(2x) too. You cannot switch sines to cosines arbitrarily.
so by using cos2x and sin2x formulas I should get (sinx)(1-2sin^2 x)+(2sinxcosx)(cosx)...right??
Correct.
then do I multiply the (2sinxcosx)(cosx) ?
Rewrite what your problem is and what you want to solve starting from the beginning please.
the problem is:
sin3x = (sinx)(3-4sin^2 x) ...PROVE THAT THEY ARE EQUAL
Ok, show some work now.
(Im going to bed in 10 min, so type fast if you want help).
ok...
first i split sin3x making sin(x+2x)
than i used the sum identity making (sinx)(cos2x)+(sin2x)(cosx)
then i used double angle identity making (sinx)(1-2sin^2 x)+(2sinxcosx)(cosx)
dunno what to do next
Factor out a sin(x).
i got it :) thanks!
new homework... will you help me with it if I have trouble?
Feel free to post your question and your work on it.
okay thank you
  • · Replies 25 ·
  • · Replies 21 ·
