Understanding Balloon Charges and Interactions
  • Thread starter Thread starter t3rom
    Balloon Charges
The discussion centers on the electrostatic interactions between five balloons with varying charges. Balloon A is positively charged, attracting Balloon B, which is negatively charged. Balloon C is also positively charged as it is repelled by Balloon A. Balloon D is positively charged and attracts Balloon B, while Balloon E is neutral, attracting negatively charged objects. The conversation clarifies that while positively charged objects attract neutral ones, the specific conditions of the problem imply that Balloon D does not affect Balloon E due to their nonconductive nature.
  • Understanding of electrostatic charges (positive, negative, neutral)
  • Knowledge of basic physics principles regarding attraction and repulsion
  • Familiarity with nonconductive materials and their properties
  • Concept of charge interactions in electrostatics
  • Research the principles of electrostatics and charge interactions
  • Learn about the behavior of nonconductive materials in electrostatic fields
  • Explore the concept of dielectric materials and their charge properties
  • Study examples of electrostatic interactions in real-world applications
Students of physics, educators explaining electrostatics, and anyone interested in understanding charge interactions and their implications in nonconductive materials.
t3rom
There are 5 balloons, A, B, C, D, and E. The following observations were made on the balloons: (I) Balloon A attracts balloon B and balloon A repels balloon C. (II) Balloon D attracts balloon B, and balloon D has no effect on balloon E. (III) A negatively-charged rod attracts both balloon A and balloon E. Figure out what are the charges on each of the balloons. There may be balloons where they have a neutral charge.
Like charges repel each other, unlike charges attract each other. Positively charged objects and neutral objects attract each other; and negatively charged objects and neutral objects attract each other.
Balloon A is + as negatively charged rod attracts it
Balloon B is - as Balloon A attracts it.
Since Balloon A (+) repels balloon C so it means Balloon C is +.
Balloon D attracts Balloon Balloon B (-) so it means Balloon D is +.
Balloon E is neutral as negatively charged objects and neutral objects attract each other.
Kindly check if this is correct.
Thank you!
t3rom said:
Balloon D is +.
If D is + and E is neutral, would D and E affect each other?
That's exactly I'm confused about.
This link might help.
Why would the question say then "balloon D has no effect on balloon E"? In what scenario is this possible?
That reads as though positively charged objects would attract each other, and neutral objects attract each other. I guess you mean a positively charged object and a neutral object attract each other.
That's true, but it is worth bearing in mind that conductors with like charges can also attract each other under the right conditions. In the present question, it seems we are to take all the objects as nonconducting.
So it means both D and E are neutral?
Yes, but it's not clear to me that you have used the correct logic to obtain the charges of A, B, and C.
The attraction of balloon A to the negatively charged rod does not necessarily imply that A is positively charged. Balloon A could be neutral. You need to use some of the other given information to deduce whether or not A is charged.
Even if balloon A were to carry a positive charge, it does not follow from this alone that B has to be negatively charged.
Yes. I think this is true for dielectric bodies also. A balloon that carries a large amount of positive charge could attract another balloon that carries a very small amount of positive charge if the balloons are near enough to each other. I'm sure we're supposed to neglect such quirks in this problem. But it's an interesting point that you have brought up.
