Identifying Cyclic Alkanes: C6H12 - C9H18 - C10H20
  • Thread starter Thread starter 312213
    Cyclic
The discussion focuses on naming cyclic alkanes and verifying the correctness of proposed names and formulas. For part a, the correct name is simply ethylcyclobutane, as numbering is unnecessary for a single substituent. In part b, the proposed name 1-methyl-3-propylcyclopentane is confirmed as correct. For part c, the correct name is 2-ethyl-1,3-dimethylcyclohexane, emphasizing the need to assign the lowest possible numbers to substituents. Overall, the participants clarify naming conventions and ensure accurate chemical formulas for the cyclic alkanes.
312213
Name each of the following cyclic alkanes, and indicate the formula of the compound.
http://img230.imageshack.us/img230/1042/organicnaming.jpg
a. The rectangle has four corners so four carbon for butane. The branch off has two carbons so eth-. Numbering the branch C as 1, the naming is 1-ethylcyclobutane with C6H12 because each corner is 1 C plus the C written and the H comes from subtracting 4 with the number of bonds connected to each of the C. Is this correct?
b. The pentagon has five corners so five corner for pentane. The branch off is prop- and meth-. Naming starts with alphabetical order so meth- first so the prop- is three. 1-methyl-3-propylcyclopentane. Logic from a., C9H18. Is this correct?
c. Hexane from six corners. Dimethyl and ethyl here. Is this named 1-ethyl-2,6-dimethylcyclohexane or 2-ethyl-1,3-dimethylcyclohexane? C10H20.
If there is a mistake, which part?
A is just ethylcyclobutane. There is no need to number the substituent, since a cycloalkane with 1 substituent will always have it at the #1 carbon. You had the formula right.
B is correct.
C is 2-ethyl-1,3-dimethylcyclohexane (you number so as to give your substituents the lowest number possible, in the absence of priority substituents such as OH). Formula is correct.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
