Identifying Direction of Induced Current - Physics Exam Prep
To identify the direction of induced current, first define the positive direction of the surface enclosed by the loop. Next, determine the direction in which the magnetic flux is increasing; for instance, if a magnet's north pole is pushed into the loop, the flux is increasing. According to Lenz's law, the induced current will create a magnetic field opposing this increase. Finally, use the right-hand rule: your thumb points in the direction of the opposing magnetic field, while your fingers curl in the direction of the induced current. Clarification on defining the positive direction of the surface is also requested for better understanding.
bayan
Hi guys.
I have a physics exam coming up in about 4 days. I have tried to learn how to identify the direction of induced current. But still I have to guess the direction which is not helpfull.
I was wondering if you could give me a link that illustrates how to identfy the direction or perhaps write down the steps that you would do in order to identify the direction of induced current.
thank you in advance
1 - Define your positive direction of the surface enclosed by the loop.
2 - find which direction the magnetic flux is increasing. If the magnet is pushed into a loop with N-pole at front(along the positive direction you defined from step 1), the magnetic flux is increasing.
3 - Len'z law says, your induced current has to create magnetic field in the opposite direction of step two.
4 - Now use right hand rule to figure out the directino of induced current. Your thumb will point to the direction you found in step 3. Rest of your finger curls along the directino of induced current.
But at any rate, this might still be confusing.
thanx. Might have to make some simple digrams for my self to fully learn this :D
"Define your positive direction of the surface enclosed by the loop."
Sorry, what does this mean>?
