If a black object warms faster during the day, does it cool faster at night?
  • Thread starter Thread starter ideogram
    Cool
The discussion revolves around the relationship between the color of an object, specifically black objects, and their rates of heating during the day and cooling at night. Participants explore concepts related to black-body radiation, real-world implications, and the mechanisms of heat exchange, focusing on both theoretical and practical aspects.
  • Some participants assert that black objects warm faster during the day and may cool faster at night due to their properties related to black-body radiation.
  • Others question whether the color directly affects cooling rates, suggesting that the temperature of the object is more significant than its color.
  • A participant mentions that while black bodies lose more energy through radiation at the same temperature, this may not be the primary cooling mechanism for larger objects.
  • It is noted that the cooling rate due to black-body radiation for large objects is relatively slow, approximately 1 degree per hour at room temperature.
  • Some participants highlight the role of emissivity, stating that dark-colored objects have higher emissivity and thus emit more energy compared to lighter objects.
  • There is a discussion about the implications of emissivity in different wavelengths, particularly infrared, and how this affects the cooling process.
Participants express differing views on the mechanisms of cooling related to color and emissivity. While some agree on the role of black-body radiation, others challenge the direct correlation between color and cooling rates, indicating that the discussion remains unresolved.
Participants mention the complexity of real-world examples, such as the cooling of cars with different upholstery colors, and the influence of atmospheric heat exchange, which may complicate the understanding of cooling rates.
This discussion may be of interest to individuals studying thermodynamics, materials science, or those curious about practical applications of physics in everyday scenarios, such as automotive design and environmental science.
ideogram
no text
lol so this is related to black-body radiation? Does this actually translate to real-world examples, say I have a car with black upholstery that gets hot fast during the day, will it cool down faster at night than a car with white upholstery? Or is it more complicated than that?
russ_watters said:
Yes!
Why is that?
No, it is no more complicated than that - you have it exactly right. Have you ever noticed condensation or frost on the outside of your car windows in the morning...but not necessarily on the hood or sides of the car? Ever wonder why...? Now you know!
This is also a substantial problem for people like me who use reflecting telescopes. The telescope tube blocks radiation from the ground from hitting the mirror, but allows the mirror to radiate heat to the atmosphere. As a result, the interior of the telescope will get cooler much faster than the air outside and the mirror (or corrector plate covering the front of the tube) will gather condensation long before you start seeing it on the ground.
Thanks!
I think there are two distinct mechanisms here.
Black body will lose more energy on radiation towards the sky at night, at the same temperature. But radiation may not be the primary cooling mechanism, especially for large and relatively cool objects. The cooling rate of an object with characteristic dimension ~1 m at room-temperature due to black-body radiation is on the order of 1 degree per hour. It will probably cool faster because of heat exchange with the atmosphere.
I still don't understand how the color of an object affects its cooling at night. The power it puts off as a black body is proportional to its temperature, not its color. Is it simply because it gets hotter during the day that it cools down faster at night?
confused about this
confused about this
Power is proportional to emissivity times temperature to the fourth power. Emissivity is higher for dark-colored objects, lower for bright colored and reflective objects.
From thermodynamics standpoint, if you were to put your object inside a black-body cavity, you'd expect it to come to equilibrium at the same temperature as walls of the cavity. Otherwise you could build a perpetual motion machine that draws energy from the difference in temperatures of the object and the cavity.
Since light-colored objects absorb less than 100% of incident radiation, it follows that they must also emit less.
Yes, however an object can only cool below ambient via radiation.
hamster143 said:
Power is proportional to emissivity times temperature to the fourth power. Emissivity is higher for dark-colored objects, lower for bright colored and reflective objects...
Further clarification: "black" doesn't just mean the color we can see, but also has to be applied to infrared to adequately deal with radiation. An object that is black in visible light color may or may not be "black" in the infrared.
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 57 ·
9K
  • · Replies 44 ·
