If a rock is dropped off a sea cliff
  • Thread starter kbrowne29
  • Tags
    Rock
In summary, the Young's Modulus of Graphite is 3.5 GPa, of Wood is around 150 GPa, of Steel is around 420 GPa, of Glass is 2.3 GPa, of Aluminium is around 6.5 GPa, and of Titanium is around 7.5 GPa.
kbrowne29
If a rock is dropped off a sea cliff, and the sound of it striking the water is heard 3.4 seconds later, how high is the cliff, assuming the speed of sound to be 340 m/s.
I don't really know where to begin with this one, and I would really appreciate the help. Thanks.
3 equations in 3 unknowns. You do the algebra.
1) h=gs2/2
2) h=vt
3) s+t=3.4
Symbols:
h=height of cliff
g=gravitational constant (9.83 m/s2)
s=time for rock to fall
t=time for sound to come back to you
v=speed of sound (340 m/s)
(h,s,t) are unknowns.
Thanks for the help. As I said before, my difficulty lay in not being able to start the problem, and now I know where I must begin. Thanks again for helping me out.
It's intersting that your value for g is 9.83. Was that a typo or is that what you've been given. I've always been told that it was 9.81.
You live in England, so the gravitational acceleration there is 9.81 m s-2. In other places the value of g is different, due to the fact that Earth is not a perfect sphere.
Where I live, in Singapore which is near the equator, the value of g is 9.78 m s-2, although in classrooms we use 9.81 m s-2 because the public education here prepares us for Cambridge papers.
I know that the Earth is not a perfect sphere, and that invariably gravity will vary. But I thought that 9.81 was an average figure denoted by SI. After all, they set the standard units for everything else so why not a standard value for g aswell.
Hmmm... I've never thought of that. I don't know...
Because the other things that they set values for are constants (or are believed to be), whereas 'g' certainly isn't. If I measure 'g'in the lab, I want to find the value of it, not see how close I am to some arbitrary average decided on by a committee.
:smile:
g is not an arbitrary unit like "1 kg" or "1 meter". It is a "constant of nature" and the correct value, to the necessary accuracy, should be used for the position on the earth. Of course, for most applications, 9.81 gives the necessary accuracy. (And, in fact, 9.8 works nicely most of the time.)
I hadn't realized it changed so much so I looked it up. The difference is a combination of distance from the center of the Earth and centrifugal force. I don't feel like doing the math right now on exactly how much of it is due to each.
The formulae is:
F' = GMm
r^2
F' is the force of attraction between two point masses of M and m.
G is the gravitational constant (6.67*10^24).
r is the distance between the two point masses.
You could take account of the fact that we're trying to mave in a straihg line and the Earth is pulling us round in a circle if you wanted to, but this effect would be smal when you take account of the radius of the earth: 40,000,000/(2[pi]), nevertheless the formula for that is:
F'' = mr * ω^2
where &omega is the angular velocity, which can be replaced by 2[pi]/T where T is the time persiod 24*3600 (24 hours in seconds), m is your mass by the way:
F'' = mr * 4 * [pi]^2 / (24*3600)^2
So the total resultant force on a mass m, F = F' - F''
Feel free to work out the values if you can be bothered.
Excuse me, but g is not a constant. It is commonly called the acceleration due to gravity, which is related to the Gravitational constant, G. The value of g depends on where it is measured, including the altitude.
Even though g is commonly called the acceleration due to gravity, the measured (and published) value of g at a certain location usually includes the effect due to the rotation of the Earth at the particular location.
the height is 578m.
Δy = [(v+v0)/2]t
v = 0, t = 3.4s.
Hi Adrian
Its Magg$,
you know, we talked before and you helped me with my coursework...
Only this time I'm talking out of my own interest...
Could you tell me what the Young's Modulus value is for:
Graphite,
Wood,
Steel,
Glass,
Aluminium,
and Titanium...
I know your going to think this is to help with coursework again because Young's Modulus is part of the AS syllabus but HONESTLY, this is through my own interest as I want more young's modulus values to do some comparisons between materials.
Please Help,
Magg$
P.S, I'm going to a lecture tomorrow about the Physics of Skydiving at Birmingham University, should be good!
http://invsee.asu.edu/nmodules/engmod/propym.html with some of them. You can probably find more with a little judicious googling. I found this one just by googling on Young's Modulus. You should generally try that kind of thing before asking here, because you get the answer quicker and (hem) learn to do independent research.
1. What will happen to the rock if it is dropped off a sea cliff?
When a rock is dropped off a sea cliff, it will fall due to the force of gravity. It will accelerate as it falls and eventually hit the water below.
2. How fast will the rock be falling when it hits the water?
The speed at which the rock falls will depend on factors such as the height of the cliff, air resistance, and the mass and shape of the rock. However, it is safe to assume that the rock will be falling at a high speed when it hits the water.
3. Will the rock break or shatter upon impact with the water?
The force of impact from falling off a sea cliff can cause a rock to break or shatter. However, the extent of damage will depend on the type and strength of the rock, as well as the surface tension of the water.
4. How deep will the rock go into the water?
The depth to which the rock will sink in the water will depend on its density and shape. If the rock is denser, it will sink deeper into the water. However, if it has a more aerodynamic shape, it may skip or bounce on the surface of the water instead of sinking.
5. What happens to the rock after it hits the water?
After hitting the water, the rock will create a splash and then sink to the bottom of the sea. Depending on the depth and current of the water, it may be carried away by the current or stay in the same spot on the seabed.
  • Classical Physics
