If a sequence is eventually bounded then it is bounded
  • Thread starter Thread starter pixelate
    Bounded Sequence
The discussion revolves around the lemma stating that if a sequence is eventually bounded, it is bounded. A participant initially uses the sequence ##\tan{\frac{\pi}{n}}## to challenge this lemma, arguing that it becomes unbounded at n=1. However, it is clarified that the sequence is not valid due to undefined values at certain points, particularly at n=2. The confusion stems from a misunderstanding of the sequence's behavior, leading to the realization that the lemma holds true when correctly applied. Ultimately, the discussion emphasizes the importance of ensuring the sequence is well-defined to assess boundedness accurately.
pixelate
Hi, I've been solving Calculus Deconstructed by Nitecki and I've been confused by a particular lemma in the book. Namely:
If a sequence is eventually bounded, then it is bounded:
that is, to show that a sequence is bounded, we need only find a number
γ ∈ R such that the inequality
|x_i| < \gamma \ \text{holds for all i ≥ K, for some K}
3. The Attempt at a Solution
[/B]
However if we consider the sequence ##\tan {\frac{\pi}{n}} ##, with n starting at 1. For terms when n is very high, we can find some value for ##\gamma## for which the condition holds and thus the sequence is bounded (according to the lemma). Yet at n=1, ##\tan {\frac{\pi}{n}} = \infty##, so the sequence cannot be bounded.
My questions are:
1. Is my reasoning at all correct in the first place ?
2. It is easy to see that my sequence does have a lower bound but no upper bound, so does the lemma only refer to one bound (But doesn't bounded mean bounded in both directions?)
Thanks for reading!
[/B]
My questions are:
Thanks for reading!
You don't have a valid sequence, so that is not a counterexample to anything.
Anyway, at ##n = 1## we have ##\tan(\pi) = 0##, so that is OK. The trouble occurs at ##n = 2##.
But, I say it again: you don't have a valid sequence of real numbers with this example.
.Oh I see, that's very illuminating thank you. Of course at n=2, the the element of the sequence is undefined and it is not infinite at all. I feel silly for making such a basic mistake now.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
