If deceleration is given instead of acceleration can i find the force
Deceleration is indeed a form of acceleration and can be used to calculate force. When deceleration is labeled as negative acceleration, the formula F = m(-a) applies. The sign of the force may vary based on the chosen coordinate system and initial conditions. Understanding the context of deceleration is crucial for accurate calculations. Therefore, force can be determined even when deceleration is provided instead of acceleration.
Champdx
If deceleration is given instead of acceleration can i find the force ?
Yes
Make sure you have a coordinate system setup and label your deceleration as negative acceleration. F==m(-a). Depending on your coordinate system, initial conditions etc.. force may still come up positive but that's not the point.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
