Undergrad If y is a function of x, then x is also function of y?
  • Thread starter Thread starter yosimba2000
    Function
If y is a function of x, it does not necessarily mean that x is a function of y unless the function is invertible. The discussion explores the implications of integrating equations involving y and x, highlighting that the relationship can change depending on the context. A key point made is that for y = f(x) to imply x = f^{-1}(y), the function must be one-to-one. An example provided illustrates that y = x^2 is a function of x, but x is not a function of y due to the lack of invertibility. The conclusion emphasizes that the relationship between the two variables is contingent on the nature of their functions.
yosimba2000
So then if you take the integral of y(x) dy = x dy, you get y^2 = xy.
But if x is a function of y, that means the equation is y(x)dy = x(y) dy, which gives you y^2 = X(y), where X is the integral of of x(y) dy?
if ##y=f(x)##, x is a function of y, i.e. ##x=f^{-1}(y)##, only if ##f## is invertible. Look up inverse function theorem, for what you need.
This appears to be an intermediate step in solving a differential equation.
Starting with y dy = x dy, if you integrate the left side you get y2 + a constant, but you can't integrate the right side. Is x dy a typo? Should it be x dx? If so, and we start with y dy = x dx, integrating both sides yields y2 = x2 + C.
The short answer to your thread title -- "If y is a function of x, then x is also function of y?" -- is "Not necessarily."
For example, if y = f(x) = x2, then y is a function of x, but x is not a function of y. As already stated, each variable is a function of the other only if both functions are one-to-one.
  • · Replies 17 ·
