I'm sorry, I am not able to generate webpage titles for user's content.
The discussion revolves around the mathematical concepts of rotation transformation generators and Lorentz group generators, focusing on their definitions, properties, and relationships within the context of quantum mechanics and Lie algebra. The scope includes theoretical aspects and mathematical reasoning related to these transformations.
  • Some participants describe rotation as a linear transformation represented by an orthogonal matrix R, which can be parameterized by Euler angles.
  • It is proposed that in quantum mechanics, an operator U(R) acts on state vectors to represent the transformation of a physical system under rotation, with the generators of rotations being represented by Hermitean operators J.
  • Participants mention that the components of J satisfy specific commutation relations, which are foundational in quantum mechanics discussions about spin.
  • One participant outlines that there are three generators of rotation associated with the rotation group SO(3) and contrasts this with the ten generators associated with Lorentz transformations, which include boost and translation parameters.
  • Another participant elaborates on the infinitesimal rotations and the antisymmetry of the matrix ω, leading to the conclusion that there are three independent elements in ω, which can be expressed in terms of the generators J.
  • There is a mention of the Poincaré group as a Lie group and its associated Lie algebra, which includes generators of Lorentz transformations.
  • Some participants express uncertainty or lack of confidence in their understanding of Lie algebra concepts, indicating a need for further clarification or exploration.
Participants generally agree on the mathematical framework surrounding rotation and Lorentz transformations, but there are varying levels of understanding and confidence regarding the implications and applications of these concepts. The discussion remains unresolved in terms of deeper insights into the implications of these generators.
Limitations include potential missing assumptions regarding the definitions of the groups and transformations, as well as unresolved mathematical steps in the derivations presented.
princeton118
What is the rotation transformation generator?
What is the Lorentz group generator?
I kind of suck at the Lie Algebra stuff, so I'll just mention some of what Steven Weinberg said in The quantum theory of fields, volume 1, chapter 2. (Great chapter, I highly recommend it even if you're not going to read the rest of the book).
A rotation is a linear transformation
[tex]x\mapsto Rx : \mathbb{R}^3\rightarrow\mathbb{R}^3[/tex]
where R is orthogonal. We can let R be a function of three parameters, e.g. Euler angles.
In quantum mechanics, there must be an operator U(R) that acts on state vectors to give us the vector that a rotated observer would use to describe the same physical system. If we take this to be a function of the parameters and Taylor expand it, the result can be expressed as
[tex]1-i\vec\theta\cdot\vec{J}+\cdots[/tex]
where the components of theta are real numbers, the components of J are Hermitean operators, and terms of second and higher order in the parameters have been omitted. The components of J are called spin operators, and they are said to be generators of rotations, because the operators in the higher order terms can be constructed from the operators in the first order terms, so the generators are all that's needed except values of the parameters to construct a particular rotation operator.
It's possible to show that the components of J must satisfy the commutation relations
[tex][J_i,J_j]=i\varepsilon_{ijk}J_k[/tex]
Most QM books start the discussion about spin with these commutation relations, and don't say much about how they are generators of rotations.
So there are three generators of rotation, called spin. If we do the same with (inhomogeneous) Lorentz transformations instead, we get ten generators instead of three (because there are ten parameters: 3 boost parameters, 3 Euler angles and 4 translation parameters). They are called boost operators, spin operators and components of four-momentum. The zeroth component of the four-momentum is the Hamiltonian. It's the generator of translations in time, and it's eigenvalues are the possible energy levels of the physical system.
The Lie algebra stuff that I suck at, goes something like this: The Poincaré group is a Lie group (meaning it's both a group and a manifold). The tangent space at the identity element can be given the structure of a Lie algebra (a vector space with a way to "multiply" its members, similar to a cross product or a commutator) called the Poincaré algebra. The members of the Poincaré group are Lorentz transformations by definition, and the members of the Poincaré algebra are generators of Lorentz transformations.
The set of all rotations:
[tex]\bar{r} = R( \theta ) {} r[/tex]
that keeps [itex]r^{2}[/itex] invariant ( i.e., [itex]\bar{r}^{2} = r^{2}[/itex] ) form a group called the rotation group SO(3) (= Special Orthogonal group in 3 dimension).
For a very small (infinitesimal) rotations, the matrix [itex]R[/itex] will differ from the unit matrix [itex]I_{3}[/itex] by an infinitesimal 3x3 matrix [itex]\omega ( \theta )[/itex] [infinitesimal matrix is a matrix whose elements are infinitesimal numbers].
Thus;
[tex]\bar{r} = \left[ I + \omega ( \theta ) \right] {} r[/tex]
or, in terms of the components [itex](x_{1},x_{2},x_{3})[/itex] of the vector r,
[tex]\bar{x}_{i} = \left[ \delta_{ij} + \omega_{ij}( \theta ) \right] {} x_{j}[/tex]
Now, the invariance condition;
[tex]\bar{x}_{i} \bar{x}_{i} = x_{j}x_{j}[/tex]
forces the matrix [itex]\omega[/itex] to be antisymmetric;
[tex]\omega_{ij} = - \omega_{ji}[/tex]
Therefore, there are only three independent elements in [itex]\omega[/itex]. So, we may write
[tex] \omega = \left( \begin{array}{ccc} 0 & - \theta_{3} & \theta_{2} \\ \theta_{3} & 0 & - \theta_{1} \\ - \theta_{2} & \theta_{1} & 0 \end{array} \right)[/tex]
We rewrite this as
[tex] \omega = i \theta_{1} J_{1} + i \theta_{2} J_{2} + i \theta_{3} J_{3} \equiv i \theta_{k}J_{k}[/tex]
where
[tex] J_{1} = \left( \begin{array}{ccc} 0 & 0 & 0 \\ 0 & 0 & i \\ 0 & -i & 0 \end{array} \right)[/tex]
[tex] J_{2} = \left( \begin{array}{ccc} 0 & 0 & -i \\ 0 & 0 & 0 \\ i & 0 & 0 \end{array} \right)[/tex]
and
[tex] J_{3} = \left( \begin{array}{ccc} 0 & i & 0 \\ -i & 0 & 0 \\ 0 & 0 & 0 \end{array} \right)[/tex]
Now it is easy to see that these J's satisfy the following commutation relations
[tex]\left[ J_{1}, J_{2} \right] \equiv J_{1}J_{2} - J_{2}J_{1} = i J_{3}[/tex]
[tex]\left[ J_{3}, J_{1} \right] = i J_{2}[/tex]
and
[tex]\left[ J_{2}, J_{3} \right] = i J_{1}[/tex]
we write these in the compact form;
[tex][ J_{i} , J_{j} ] = i \epsilon_{ijk} J_{k}[/tex]
In quantum mechanics, the components of the angular momentum operator satisfy the same commutation relations. Therefore, one speaks of the angular momentum operator as the generator of the rotation group SO(3).
Mathematically, the matrix [itex]\omega[/itex] is an element of 3-dimensional vector soace [the Lie algebra of SO(3)] whose basis vectors,[itex]J_{i}[/itex], satisfy the above-derived commutation relations [Lie brackets]. The components [itex]\theta_{i}[/itex] of the Lie algebra element [itex]\omega[/itex], play the role of local coordinates of the group manifold. All elements of the group SO(3) can be represented as exponentials of Lie algebra elements, i.e., the matrix [itex]R( \theta )[/itex] can now be written as
[tex]R = \exp (i \theta_{k} J_{k} )[/tex]
Doing the same thing with Lotentz transformations leads to six 4x4 matrices (generators).
Try it yourself.
regards
sam
Thus;
We rewrite this as
where
and
and
Try it yourself.
regards
sam
This should be framed. You just tied a lot of things together which were popping about.
  • · Replies 0 ·
  • · Replies 31 ·
  • · Replies 23 ·
