High School Understanding the Inconsistencies of Imaginary Numbers
The discussion centers on the inconsistencies in calculating the square root of -i², leading to two different results: 1 and -1. The first equation is deemed correct as it simplifies to √1, while the second is incorrect due to the misuse of the square root property that applies only to nonnegative numbers. The conversation highlights that the square root function in the context of complex numbers can yield two answers, necessitating the use of ± notation for clarity. It emphasizes that the standard radical notation assumes a positive result, which can be misleading when dealing with complex numbers. Understanding these nuances is crucial for accurate calculations involving imaginary numbers.
Tian En
I ran into such problem. Not sure if some one can help.
$$\sqrt{-i^2}=\sqrt{-1\times i^2}=\sqrt{-1\times -1}=\sqrt{1}=1$$
I also have
$$\sqrt{-i^2}=\sqrt{-1}\times \sqrt{i^2}=\sqrt{-1}\times i=i\times i=-1$$
Can anyone explain to me the inconsistencies?
Mathematics news on Phys.org
My interpretation is that both of these equations are correct since a square root yields both a positive and a negative answer.
I also have
I disagree. The first equation is find, because the radical on the left is essentially ##\sqrt 1##, which is 1.
The second equation is not correct, because the property that ##\sqrt a \sqrt b = \sqrt {ab}## is applicable only if both a and b are nonnegative. This is pointed out in the Insights article that @fresh_42 cited.
In addition, the real square root of a nonnegative number represents a single number, so it's not correct to say that, for example, ##\sqrt 4 = \pm 2##.
Likes jbriggs444
Either answer is incomplete. The best answer is ±1. Once complex numbers are allowed, you need to be aware that the square root function always has two possible answers.
Using the '√' notation together with its assumption of a positive answer is treacherous in a context where complex numbers have been introduced. The '√' radical notation implies that the positive square root of a positive number will be used. Use '±√' if you want both to be considered. But once complex numbers are involved, those conventions do not apply.
Likes fresh_42
You make a good point, but the first equation starts off with ##\sqrt{-i^2}##. Since -i2 = -(-1) = 1, we are taking the square root of a positive number, and complex numbers are not involved.
Thank you.
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 23 ·
36K
