Immediate Acceleration Possible?
  • Thread starter Thread starter Natko
    Acceleration
The discussion centers on the theoretical possibility of an object (Object B) immediately accelerating to the velocity of another object (Object A) that maintains a constant velocity of 100 mph upon impact. Participants conclude that immediate acceleration is impossible due to the laws of physics, specifically conservation of momentum and energy, as well as the impossibility of infinitely rigid bodies. The conversation emphasizes that energy transfer during a collision results in some energy being dissipated, preventing Object B from achieving Object A's velocity instantaneously.
  • Understanding of Newton's laws of motion
  • Familiarity with conservation of momentum and energy
  • Basic knowledge of collision physics
  • Concept of rigid body dynamics
  • Research Newton's laws of motion in detail
  • Study the principles of conservation of momentum and energy in collisions
  • Explore rigid body dynamics and the implications of material stiffness
  • Investigate the effects of energy dissipation in inelastic collisions
Physics students, educators, and anyone interested in the principles of motion and collision dynamics will benefit from this discussion.
Natko
Is it possible that an object changes velocity immediately?
For example, Object A is ALWAYS traveling at a constant velocity (say 100mph). Its velocity never changes.
If Object B (which is at rest) were in the path of Object A and Object A were to slam into Object B, would Object B suddenly and immediately accelerate to 100mph in no time, since Object A never changes its velocity (at least theoretically)?
First it would be very unlikely that object B would have a velocity equal to object A, since all of the energy from object A would have to transfer into object B. Some energy instead is dissipated as heat and some as noise, also some will remain in object A as it bounces away. The remaining energy will be what causes object B to move.
Also, object B will not move away from object A right away, since both materials would deflect under the impact. Basically, think of a set of very stiff springs. Those springs will deflect building up potential energy until they reach a point that it will turn into kinetic energy causing object A and B to move in a certain direction, which depends on the angle of the impact.
Also, object B will not move away from object A right away, since both materials would deflect, first under the impact. Basically, think of a set of very stiff springs. Those springs will deflect building up potential energy until they reach a point that it will turn into kinetic energy causing object A and B to move in a certain direction, which depends on the angle of the impact.
That is very true, but I was talking theoretical and emphasized that Object A's velocity cannot change at all. Then, would immediate acceleration be possible?
No. Essentially what you want is an infinitely massive (and rigid) body, which is of course impossible.
So you're saying that if you had an infinitely massive and rigid body, immediate acceleration would be possible.
Well, not really. Such objects don't exist, and I don't like statements like this (similar to if you had an infinite amount of energy you could accelerate a massive object to the speed of light). To be precise, in the limit as mass and stiffness increase without bound, time of acceleration asymptotes to zero.
Concur with Nabeshin.
The laws of physics (Einstein's relativity is particular) forbid infinitely rigid materials, unstoppable forces and infinite accelerations.
If you want to ask what would happen if something did violate the laws of physics then the answer is, is always, you get pink unicorns and fairies.
You're asking what would happen if something that couldn't happen happened.
Not even that, but you specified MANY thing that couldn't happen. You can't have a "body that doesn't change velocity". That violates conservation of momentum, conservation of energy, Newton's laws, and who knows how many other basic physics concepts. Infinite mass? Infinite rigid body?
Might as well ask what would happen if God himself slammed into your object. I suppose it would accelerate infinitely fast, but then that means that the force on it is infinitely large, and so the object would probably get instantly annhilated. Unless, of course, God instnatly re-created it.
