gimak
- 56
- 2
Just problem 19C.
P=IV=Ieiwt*Veiwt. T
P = IVe2iwt=IVcos(2wt). What did I do wrong?
The discussion focuses on the calculation of average power in AC circuits, specifically addressing problem 19C. It emphasizes the importance of using real voltage and current values rather than their complex forms for accurate power calculations. The relationship between complex voltage, current, and impedance is defined using the equation U=ZI, where Z is the complex impedance. To find the average power, one must integrate the instantaneous power over a complete cycle and divide by the period T.
PREREQUISITESElectrical engineering students, circuit designers, and professionals working with AC power systems will benefit from this discussion, particularly those focused on power calculations and impedance analysis.
gimak said:Homework Statement
Just problem 19C.
P=IV=Ieiwt*Veiwt. T
ehild said:The complex form of power and voltage can be used for linear operations only (addition, multiplication with constant).
You can do linear operations with the complex voltages and currants, but in any other case, the real quantities should be used.gimak said:So this means that we can't use their complex form because whatever operators we use on them are only linear? Also, is another way to understand this is that since power & voltage are real, that means we must take their real part when doing operations with them?
