Implicit Differentiation Clarification
The discussion revolves around implicit differentiation, specifically focusing on the equation 2x² - 3y² = 4. Participants are exploring the process of differentiating equations where y is treated as an implicit function of x, and they are questioning the application of the chain rule and the introduction of dy/dx in their calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the differentiation process and the role of dy/dx, with some expressing confusion about its introduction and the rules governing its use. There is a focus on understanding the chain rule and its application in implicit differentiation.
The conversation is ongoing, with participants providing insights and clarifications to each other. Some have offered guidance on the chain rule and algebraic manipulation, while others are still grappling with the concepts and seeking further explanations.
There are indications of varying levels of algebra proficiency among participants, which may be impacting their understanding of the differentiation process. Some participants are also exploring additional related problems, indicating a broader context of learning and inquiry.
  • #31
I am hoping my addition of binomials is correct:
[tex]xy^{2} - 3x^{2}y +x =1[/tex]
[tex]\frac {d(xy^{2}-3x^{2}y+x)}{dx} = \frac {d(1)}{dx}[/tex]
[tex](2yx\frac{dy}{dx}+y^{2}) - (3x^{2}\frac{dy}{dx}+6xy)+1 = 0[/tex]
then I change the subtraction to addition and move the 1:
[tex](2yx\frac{dy}{dx}+y^{2}) + (-3x^{2}\frac{dy}{dx}-6xy) = -1[/tex]
[tex]2yx\frac{dy}{dx} - 3x^{2}\frac{dy}{dx} +y^{2}-6xy = -1[/tex]
[tex]2yx\frac{dy}{dx} - 3x^{2}\frac{dy}{dx} +y^{2} = -1 + 6xy[/tex]
[tex]2yx\frac{dy}{dx} - 3x^{2}\frac{dy}{dx} = -1 + 6xy - y^{2}[/tex]
[tex]\frac{dy}{dx}(2yx - 3x^{2}) = -1 + 6xy - y^{2}[/tex]
[tex]\frac{dy}{dx}= \frac {-1 + 6xy - y^{2}} {2yx - 3x^{2}}[/tex]
  • #32
I'm with you up to here:
[tex] \frac{dy}{dx}= \frac {-1 + 6xy - y^{2}} {2yx - 3x^{2}} [/tex]
That's good. It's actually good work, then you went completely off the radar using some algebra rule you apparently just made up. Will you stop doing that?
This is getting to the point were I'm going to have to ask you not only to show your steps but to show the justification for each step. Otherwise, you are never going to learn to self-check these steps. You do fine for a while and then you just make a completely bongo move. Do you know that the manipulations you do in algebra are largely confined to i) adding or subtracting the same quantity from both sides an equation and ii) multiplying or dividing both sides of an equation by the same quantity? They aren't just like, randomly rearranging symbols in vaguely plausible ways.
How would you justify the step after that where you just bleeped out an xy from the numerator and denominator?
  • #33
well I checked everything up to the point that I messed up, I thought that same values in the numerator and the denominator cancel. Since x*y = y*x and x=x and y=y. I definitely didn't just rearrange the symbols in vaguely plausible ways... but after checking the simplification (i will call it that) i see that I was wrong in that regard. Really the problem lies in me having to recall the correct way some step is done that I haven't used much recently, and vaguely remember from high school, I removed the two last steps since they are wrong
Not that it matters much since I evidently made up my own rule on this problem but did you look at the problem posted before this one? Pretty sure that one is 100% the first time around. I should just stop making assumptions when posting a problem. The last result I have on my board for the problem you just posted about is where you said that it was good. Usually I'll think that I see something else that can be done after I get it all written up and don't bother to check at that point... So, yeah
  • #34
Sure. The main point is you can add/subtract to both sides of equation as in a=b+c -> a-c=(b+c)-c -> a-c=b or you can multiply/divide in a similar pattern. That's all. Ask yourself if that's REALLY what you are doing before you do anything. Cancelling the xy doesn't fall into either of those categories. Then maybe you won't have to check so much.
  • #35
[tex]2xy^{-2}+x^{-2} =y[/tex]
[tex]-4xy^{-3}\frac{dy}{dx} + 2y^{-2} - 2x^{-3} = \frac {dy}{dx}[/tex]
[tex]-4xy^{-3}\frac{dy}{dx} + 2y^{-2} = \frac {dy}{dx} + 2x^{-3}[/tex]
[tex]-4xy^{-3}\frac{dy}{dx} = \frac {dy}{dx} + 2x^{-3}- 2y^{-2}[/tex]
[tex]-4xy^{-3}\frac{dy}{dx} -\frac {dy}{dx} = 2x^{-3}- 2y^{-2}[/tex]
[tex]\frac{dy}{dx}(-4xy^{-3} -1) = 2x^{-3}- 2y^{-2}[/tex]
[tex]\frac{dy}{dx} = \frac {2x^{-3}- 2y^{-2}} {-4xy^{-3} -1}[/tex]
  • #36
Looks ok to me.
  • #37
[tex]y = sin(xy)[/tex]
[tex]\frac {dy}{dx} = cos(xy) * (x\frac{dy}{dx} +y)[/tex]
[tex]\frac {dy}{dx} = (x\frac{dy}{dx})cos(xy)+(y)cos(xy)[/tex]
[tex]\frac {dy}{dx}(1 -(x)cos(xy))= (y)cos(xy)[/tex]
[tex]\frac {dy}{dx}= \frac{y*cos(xy)} {1 -x*cos(xy)}[/tex]
  • #38
And another:
[tex]x = cos^{2} (y)[/tex]
[tex]1 = (2cos(y))(-sin(y))(\frac{dy}{dx})[/tex]
[tex]\frac {1} {(2cos(y))(-sin(y))} = \frac {dy}{dx}[/tex]
  • #39
Hopefully getting the hang of this:
[tex]y = e^{x+2y}[/tex]
[tex]\frac {dy}{dx} = e^{x+2y} * (1+2\frac{dy}{dx})[/tex]
[tex]\frac {dy}{dx} = e^{x+2y} + 2\frac{dy}{dx}e^{x+2y}[/tex]
[tex]\frac {dy}{dx} - 2\frac{dy}{dx}e^{x+2y} = e^{x+2y}[/tex]
[tex]\frac {dy}{dx}(1 - 2e^{x+2y}) = e^{x+2y}[/tex]
[tex]\frac {dy}{dx} = \frac {e^{x+2y}} {(1 - 2e^{x+2y})}[/tex]
  • #40
Yes, I think you've gotten the hang of it.
  • #41
One more for good measure? It's the last question in the section any way
[tex]y^{2} = ln (2x+3y)[/tex]
[tex]2y\frac{dy}{dx} = \frac {1} {2x+3y} * (2+3\frac{dy}{dx})[/tex]
[tex]2y\frac{dy}{dx} = \frac {2} {2x+3y} + \frac {3}{2x+3y}\frac{dy}{dx}[/tex]
[tex]2y\frac{dy}{dx} - \frac {3}{2x+3y}\frac{dy}{dx} = \frac {2} {2x+3y}[/tex]
[tex]\frac{dy}{dx}(2y - \frac {3}{2x+3y})= \frac {2} {2x+3y}[/tex]
which is to say:
[tex]\frac{dy}{dx}(\frac {(2y)(2x+3y)}{2x+3y} - \frac {3}{2x+3y})= \frac {2} {2x+3y}[/tex]
[tex]\frac{dy}{dx}(\frac {(2y)(2x+3y)-3}{2x+3y})= \frac {2} {2x+3y}[/tex]
[tex]\frac{dy}{dx}= \frac {\frac {2} {2x+3y}} {\frac {(2y)(2x+3y)-3}{2x+3y}}[/tex]
[tex]\frac{dy}{dx}= \frac {2} {2x+3y} *\frac {2x+3y}{(2y)(2x+3y)-3}[/tex]
[tex]\frac{dy}{dx}= \frac {(2)(2x+3y)} {(2x+3y)(2y)(2x+3y)-3}[/tex]
[tex]\frac{dy}{dx}= \frac{2} {(2y)(2x+3y)-3}[/tex]
  • #42
Last one?? Promise? That one looks good to me.
  • #43
Yep that's the last one, thanks 1000x for all the help and patience Dick!
  • #44
Very welcome. It's nice to see someone learn from mistakes and learn not to repeat them. Wish that happened more often around here. You are welcome back anytime!
  • #45
Oh I am sure that I will have more questions soon enough as I am only on chapter 3 of 13 in this particular book, but I am glad to hear that I didn't ask too many questions as I had suspected.
  • · Replies 25 ·
  • · Replies 24 ·
