What is the Second Derivative of Implicitly Differentiated Function?
To find the second derivative y'' of the implicitly defined function 5x^2 + 3y^2 = 4, the first derivative y' was calculated as -5x/3y. The second derivative was initially expressed using the quotient rule, leading to a complex equation involving y' and x. By substituting y' with -5x/3y and simplifying, the expression was further refined. Ultimately, the final result for y'' was determined to be -20/9y^3, demonstrating the importance of substitution and simplification in implicit differentiation.
Lion214
Determine y'' when 5x^2 + 3y^2 = 4.
So I found the first derivative using the power rule and chain rule,
10x + 6yy' = 0
Which I then solved for y',
y' = -10x/6y = -5x/3y
Next I found the second derivative using quotient rule,
y'' = (-15y + 15xy')/(3y)^2
This is the part where I am lost, since all the multiple choice answers involve no y' nor is there a x.
I don't know how to get rid of the x and the y' in the equation. Any help will be appreciated as to simplifying the equation even further and as to how.
Substitute the form of y' you have into the expression for y'' and simplify.
Thanks statdad!
so here's what I did,
I substituted y' with -5x/3y and got
y'' = (-15y + 15x(-5x/3y))/(3y)^2 = (-15y - 25x^2/y)/(3y)^2 = (-15y^2/y - 25x^2/y)/(9y^2) = (-15y^2-25x^2)/9y^3
But I still had to get rid of the x, so I used the original equation to solve for x^2, which was;
x^2 = (4-3y^2)/5
Which I then use to simplify even further,
y'' = (-15y^2 - 25((4 - 3y^2)/5))/9y^3 = ((-75y^2 - 100 + 75y)/5)/9y^3
In which the answer is -20/9y^3.
Thanks for the insight. For some reason I didn't see that.
You are welcome. The little bit of ``extra'' work you've just gone through is handy to remember for these types of problems - I would state with near 100% certainty you'll see similar things in the future.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 25 ·
