Why iπ in Contour Integration for Improper Integral Involving ln?
The integral $$\int_0^\infty \frac{\ln(x)}{1+x^2} dx$$ evaluates to zero, as demonstrated through various methods including substitution and symmetry arguments. The substitution $$x = \frac{1}{t}$$ leads to the conclusion that the integral is equal to its negative, confirming that it must be zero. Additionally, integrals of the form $$\int_0^\infty \frac{\ln(x)^{2n+1}}{1+x^2} dx$$ also yield zero, while those with even powers can be solved using complex analysis techniques. The discussion emphasizes the utility of contour integration and the properties of logarithmic functions in evaluating improper integrals.
  • Understanding of improper integrals
  • Familiarity with logarithmic functions and their properties
  • Basic knowledge of complex analysis and contour integration
  • Experience with substitution methods in integration
  • Study the properties of logarithmic integrals, particularly $$\int_0^{\infty} \frac{\ln(x)}{1+x^2} dx$$
  • Learn about contour integration techniques, specifically keyhole contours
  • Explore differentiation under the integral sign as a method for evaluating integrals
  • Investigate the Dirichlet Beta function and its applications in integral evaluation
Mathematicians, students of calculus and complex analysis, and anyone interested in advanced techniques for evaluating improper integrals.
jacobi1
How would I evaluate $$\int_0^\infty \frac{\ln(x)}{1+x^2} dx$$?
If you know about contour integration, integrate it round a keyhole contour.
$$\int_0^\infty \frac{\ln(x)}{1+x^2} dx = -\int_0^\infty \frac{\ln(x)}{1+x^2} dx$$
Actually this can be generalized to
$$\int_0^\infty \frac{\ln(x)^{2n+1}}{1+x^2} dx =0 $$
On the other hand
$$\int_0^\infty \frac{\ln(x)^{2n}}{1+x^2} dx$$
Can be solved using complex analysis approaches .
Could I use differentiation under the integral sign or any elementary integration techniques to do it? I don't know complex analysis :(
There is no need to use complex analysis .The integral is equal to $0$ as I pointed to prove that make the substitution $x = \frac{1}{t}$ which reslults in $I = -I $ only possibly if $I=0$.
Oh, I see. Thanks! :D
Integrals of this type are solved in elementary way with the procedure described in... http://mathhelpboards.com/math-notes-49/integrals-natural-logarithm-5286.html
This integral however is 'even more elementary' because splitting the integral in two parts and with the substitution $x= \frac{1}{t}$ in the second part You obtain...
$\displaystyle \int_{0}^{\infty} \frac{\ln x}{1 + x^{2}}\ dx = \int_{0}^{1} \frac{\ln x}{1 + x^{2}}\ dx + \int_{1}^{\infty} \frac{\ln x}{1 + x^{2}}\ dx = \int_{0}^{1} \frac{\ln x}{1 + x^{2}}\ dx - \int_{0}^{1} \frac{\ln t}{1 + t^{2}}\ dt =0\ (1)$
Kind regards
$\chi$ $\sigma$
The exact value of the integral, obtained in absolutely elementary way, is zero and that allows us to do an interesting analysis about the keyhole contour integration when a logarithm is in the function to be integrated. Before doing that it is necessary to answer to the following question: what is the principal value of $\displaystyle \ln (e^{i\ \theta})$ for $0 \le \theta < 2 \pi$?... Most of the 'Holybooks' report the discontinous function that also 'Monster Wolfram' reports...
ln (e^(i x)) x from 0 to 2 pi - Wolfram|Alpha+
In my opinion such a definition is questionable because if we intend to integrate the function $\displaystyle f(z)= \frac{\ln z}{1+z^{2}}$ along the path illustrated in the figure... http://d4ionjxa82at6.cloudfront.net/a8/bb/i75414440._szw380h285_.jpg
... we find that that's impossible because the discontinuity of the term $\ln z$ when the negative x-axis is crossed. If we adopt the 'more logical' definition...
$\displaystyle \ln (e^{i\ \theta}) = i\ \theta,\ 0 \le \theta < 2\ \pi\ (1)$
... we find that f(z) has two poles in z=i and z=-i and one 'brantch point' in z=0, so that keyhole integration alonf the path of the figure can be performed. First step is to compute the residues...
$\displaystyle r_{1}= \lim_{z \rightarrow i} f(z)\ (z-i) = \frac{\pi}{4}$
$\displaystyle r_{2}= \lim_{z \rightarrow - i} f(z)\ (z+i) = - \frac{3\ \pi}{4}\ (2)$
... so that the integral along the path of the figure is...
$\displaystyle \int_{A B C D} f(z)\ dz = i\ \int_{0}^{2\ \pi} \frac{R\ (\ln R + i\ \theta)}{1 + R^{2}\ e^{2\ i\ \theta}}\ e^{i\ \theta}\ d \theta + \int_{R}^{r} \frac{\ln x}{1+x^{2}}\ dx + 2\ \pi\ i\ \int_{R}^{r} \frac{d x}{1+x^{2}} +$
$\displaystyle +i\ \int_{2\ \pi}^{0} \frac{r\ (\ln r + i\ \theta)}{1 + r^{2}\ e^{2\ i\ \theta}}\ e^{i\ \theta}\ d \theta + \int_{r}^{R} \frac{\ln x}{1 + x^{2}}\ d x = 2\ \pi\ i\ (r_{1} + r_{2})= - i\ \pi^{2}\ (3)$
Now if we push r to 0 and R to infinity we find that the first and fourth term vanishes and (3) is reduced to the trivial identity $- i\ \pi^{2} = -i\ \pi^{2}$ that doesn't give any information about the value of the integral $\displaystyle \int_{0}^{\infty} \frac{\ln x}{1 + x^{2}}\ dx$. May be that some different way has to be found...
Kind regards
$\chi$ $\sigma$
Here's an alternative evaluation for
$$\int_z^{\infty}\frac{\log x}{(1+x^2)}\,dx$$
For the sake of simplicity, I'll assume z > 1 here, although it's not particularly complicated if z <1. Make the reciprocal substitution $$x \to 1/y\,$$ to obtain :
$$\int_z^{\infty}\frac{\log x}{(1+x^2)}\,dx=\int_0^{1/z}\frac{\log(1/y)}{1+(1/y)^2}\frac{dy}{y^2}=$$
$$-\int_0^{1/z}\frac{\log x}{(1+x^2)}\,dx=\log z\tan^{-1}(1/z)+\int_0^{1/z}\frac{\tan^{-1}x}{x}\,dx$$That last integral is the Inverse Tangent Integral, a transcendental function in it's own right defined by:
$$\text{Ti}_2(z)=\int_0^z\frac{\tan ^{-1}t}{t}\,dt$$So in short, for z > 1, your answer is:
$$\int_z^{\infty}\frac{\log x}{(1+x^2)}\,dx=\log z\tan^{-1}(1/z)+\text{Ti}_2(1/z)$$Incidentally, by noting that
$$\tan^{-1}x+\cot^{-1}x=\tan^{-1}x+\tan^{-1}(1/x)=\frac{\pi}{2}$$
it is easy enough to deduce the inversion relation for the Inverse Tangent Integral:
$$\text{Ti}_2(z)+\text{Ti}_2(1/z)=\int_0^z\frac{\tan ^{-1}t}{t}\,dt+\int_0^z\frac{\tan ^{-1}(1/t)}{t}\,dt=$$
$$\frac{\pi}{2}\int_0^z\frac{dt}{t}=\frac{\pi}{2} \log z$$So the final evaluation of your integral could just as easily be re-written as:$$\int_z^{\infty}\frac{\log x}{(1+x^2)}\,dx=\log z\cot^{-1}z+\frac{\pi}{2} \log z-\text{Ti}_2(z)$$I hope that helps! :D
Gethin
Furthermore, note that
$$\int_0^{\infty}\frac{\log x}{(1+x^2)}\,dx=\int_0^{\pi/2}\log(\tan x)\,dx=$$
$$\int_0^{\pi/2}\log(\sin x)\,dx-\int_0^{\pi/2}\log(\cos x)\,dx= 0$$
Since
$$\int_0^{\pi/2}\log(\sin x)\,dx=\int_0^{\pi/2}\log(\cos x)\,dx=-\frac{\pi}{2}\log 2$$
Follow the link for a bit more about the Inverse tangent integral... Inverse tangent integral : Special Functions
On the other hand
Hello Z! (Sun)Your results above have a very simple explanation... ( I know you know this, I just thought it worth adding to this 'ere thread ;) )
Let
$$\mathcal{T}_m(\theta)=\int_0^{\theta}\log^m(\tan x)\,dx$$
Substituting $$y=\tan x\,$$ in $$\mathcal{T}_m(\theta)\,$$ and setting $$\theta=\pi/4\,$$ yields
$$\mathcal{T}_m(\pi/4)=\int_0^{\pi/4}\log^m(\tan x)\,dx=\int_0^1\frac{(\log x)^m}{(1+x^2)}\,dx$$
Now expand the denominator $$(1+x^2)^{-1}\,$$ into the infinite series
$$\frac{1}{(1+x^2)}=\sum_{k=0}^{\infty}(-1)^kx^{2k}$$
and insert that into the integral:
$$\int_0^1\frac{(\log x)^m}{(1+x^2)}\,dx=\sum_{k=0}^{\infty}\int_0^1x^{2k}(\log x)^m\,dx$$But...
$$\int_0^1x^n(\log x)^m\,dx = \frac{(-1)^mm!}{(n+1)^{m+1}}$$
Hence
$$\int_0^1\frac{(\log x)^m}{(1+x^2)}\,dx=(-1)^mm!\,\sum_{k=0}^{\infty}\frac{(-1)k}{(2k+1)^{m+1}}$$
This is none other than the Dirichlet Beta function, defined by:
$$\beta(x)=\sum_{k=0}^{\infty}\frac{(-1)^k}{(2k+1)^x}$$
Which, amongst others, has the special value $$\beta(2) = G\,$$ (Catalan's contsant).
So
$$\int_0^{\pi/4}\log^m(\tan x)\,dx=(-1)^mm!\,\beta(m+1)$$Finally, observe that
$$\int_0^{\pi/4}\log^m(\tan x)\,dx+\int_{\pi/4}^{\pi/2}\log^m(\tan x)\,dx=\int_0^{\pi/2}\log^m(\tan x)\,dx$$
Substitute $$x=\pi/2-y\,$$ in the second integral to get
$$\int_0^{\pi/4}\log^m(\tan x)\,dx-\int_{\pi/4}^0\log^m(\cot x)\,dx=$$
$$\int_0^{\pi/4}\log^m(\tan x)\,dx+(-1)^m\int_0^{\pi/4}\log^m(\tan x)\,dx=$$
$$[1+(-1)^m]m!\,\beta(m+1)$$
Hence$$\int_0^{\pi/2}\log^{2m}(\tan x)\,dx=2\, m!\,\beta(2m+1)$$
and
$$\int_0^{\pi/2}\log^{2m+1}(\tan x)\,dx=0$$
First change the variable. Substitute for x such x = exp(t). Then the derivative of x is exp(t) dt.
The limits of the new integral are the same.
Next, turn to the contour. Instead of a circle or semi-circle, use a rectangle. The lower bound is the real axis, from -R to R; the upper bound is parallel and above the real axis at -R + i\pi to R + i\pi. The left boundary goes from the real axis at -R to the line parallel axis from -R + i\pi to R + i\pi. A similar situation exists for the right boundary.
Why i\pi?
  • · Replies 19 ·
