How Is Impulse Calculated in Baseball Physics?
The impulse delivered to a baseball weighing 0.142 kg, initially thrown at 19.5 m/s and then hit back at 26.6 m/s, is calculated using the formula F*t = mvf - mvi. The correct impulse magnitude is 6.541 kg·m/s, accounting for the direction of velocities. The average force exerted by the bat on the ball, given a contact time of 0.00109 seconds, is approximately 6000.92 N. This calculation confirms the high force experienced during a baseball hit.
  • Understanding of impulse and momentum concepts
  • Familiarity with the equation F*t = mvf - mvi
  • Basic knowledge of physics regarding forces and motion
  • Ability to perform calculations involving units of kg·m/s and N
  • Study the concept of impulse in physics
  • Learn about momentum conservation in collisions
  • Explore the effects of contact time on force calculations
  • Investigate real-world applications of impulse in sports physics
Students studying physics, particularly those focusing on mechanics, as well as coaches and athletes interested in the physics of baseball and sports performance analysis.
GiantSheeps
A(n) 0.142 kg baseball is thrown with a speed
of 19.5 m/s. It is hit straight back at the
pitcher with a final speed of 26.6 m/s.
What is the magnitude of the impulse delivered
to the ball?
Answer in units of kg · m/s
(part 2) Find the average force exerted by the bat on
the ball if the two are in contact for 0.00109 s.
Answer in units of N
F*t=mvf-mvi
m= 0.142 and vf = 26.6, so mvf = 3.772, vi = 19.5 so mvi = 2.769
3.772 - 2.769 = 1.0082
which was wrong of course...
i think i need to do something with the t in the equation, but there is no t given in the problem
i also tried it with vi = 0, since velocity would be zero while the ball s on the bat, but that answer (3.772) was wrong as well
You forgot to take the direction (and thus the sign) of the velocities into account.
Likes GiantSheeps
Hi,
Is the ball hit in the same direction it is first thrown?
Likes GiantSheeps
oh okay i see, so instead of 3.772 - 2.769, it would be 3.772 + 2.769 = 6.541?
it is! thank you so much! for the second part of the question, I would divide the impulse by the time? 6.541/.00109 = 6000.917431 ... that seems a bit large though...
oh wait nevermind, this is a baseball being hit off of a bat, those things come off HARD. haha if anything that 6000 number seems a bit on the small side... it is the correct answer though so thank you thank you so much
  • · Replies 19 ·
