Impulse is the product of force and time
Impulse is defined as the product of force and time, and it is equal to the change in momentum of an object. A moving object does not inherently possess impulse; rather, it can give or receive impulse during interactions with other objects, resulting in changes to its momentum. The relationship between force, impulse, and momentum is mathematically expressed as F = dp/dt, leading to the conclusion that impulse is the integral of the force-time curve. Therefore, while an object in uniform motion may not currently experience force, it has previously received impulse to achieve its existing momentum.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of momentum and impulse
  • Knowledge of calculus, specifically integration
  • Basic grasp of force-time graphs
  • Study the relationship between impulse and momentum in detail
  • Explore the mathematical derivation of impulse from force-time graphs
  • Learn about real-world applications of impulse in collision scenarios
  • Investigate the implications of impulse in systems with varying forces over time
Physics students, educators, and professionals in mechanics who seek to deepen their understanding of impulse and its relationship to momentum in dynamic systems.
Aladin
I am in great confusion in impulse term.
As Impulse is the product of force and time and it is equal to change in momentum.
Does a moving object have impulse? if not then why not?
A moving object has momentum. If the object interacts with a second object, it may receive an impulse during the interaction and its momentum will change as a result. (An impulse is just a force acting for some time.)
Impulse.?
A moving object has momentum. It can give an impulse to another object and in the process receive an impulse. Both will have their momenta changed, but the law of conservation of momentum holds good.
It won’t be proper to say that an object has impulse. You can say that an object gives or receives an impulse which is the same as saying “ an object changes the momentum of another object and gets its own momentum changed”.
F = ma, right? Also, F = m(dv/dt), right? Therefore, F = d(mv)/dt = dp/dt, right?
Now, multiply by dt on both sides to get Fdt = dp. But Fdt is dI. So, dI = dp. A differential increase in impulse is equal to a differential increase in momentum.
Or, we can integrate both sides of the equation Fdt = dp. The integral of Fdt is the total Impulse, I , and the integral of dp is total momentum, p. Therefore I = p. So, if an object has momentum p then it has received a total impulse of I at some point.
Keep in mind that we are assuming zero initial conditions, so that the impulse at the time before the force F was applied is ZERO, and therefore the initial momentum is zero.
Simple as that.
A moving object with a certain amount of momentum received an impulse at one point in order to gain the momentum it has. But if its momentum is now constant then there is no force applied (dp/dt = F = 0) and therefore there is no increase in total impulse.
But I suppose you can say that an object moving at a constant velocity of 5 m/s has an impulse even if the force is zero at present, because at a certain time in the past the object's force curve was non-zero, and therefore it had an impulse. Again, impulse is the integral of the force-time curve for an object, and even if the force is currently zero doesn't mean it was zero at some time in the past. And a F vs. t graph that is zero at time t = 5 seconds doesn't mean it is zero at time t = 2 seconds. The object still has an impulse even at time t = 5 seconds because there was area underneath the curve in the past.
I think the question of using the term ‘impulse’ comes into picture when a force comes into play. Otherwise you will have to say that all moving bodies have impulse and the terms ‘impulse’ and ‘momentum’ will have to be used without any distinction. [You never think of the term ‘impulse’ in the case of a body in uniform motion]. It is the ‘force’ which is to be given the importance when one uses the term ‘impulse’. This is only a question of proper usage of terms even when we agree that impulse is equal to the change in momentum.
  • · Replies 138 ·
  • · Replies 18 ·
