Impulse-momentum theorem for rotating disk
28 replies · 4K views
freshbox
I have abit of problem understanding this 2 question, I would appreciate if someone can guide me along.
For diagram 1 (Left)
I interpret the condition as: At 0sec, initial velocity is 0, At 5sec final velocity is unknown.
For diagram 2 (Right)
I interpret the condition as: At 0 sec, initial velocity is 0, At 3sec final velocity is 14.5m/s
Please let me know if I get any of the condition wrong, thank you.
I think you understand the conditions correctly.
o_0 hmm strange then how come i cannot get the answer...
For Diagram 1 part A
M1=mv
=0
M2=mv
=(20)(V2)
=20V2
M1+I1-2=M2
981-5TA=20V2
5TA=981-20V2
TA=196.2-4V2
Ans is TA=196.2-4V
4V2 and 4V are both different meaning right?
You mean the 75N force?
What has it got to do with part A?
You have already solved part A as far as I can tell.
My Answer is: TA=196.2-4V2
Question Ans is : TA=196.2-4V
Is there any difference between V2 and V? one is initial one is final.
The initial velocity is zero per the conditions ("released at t = 0"). So v can only be the final.
Up to you. You can say "let's denote the velocity at t = 5 s as V" or in any other way. That does not change the underlying physics. You just need to know what denotes what.
Part B
M1=Iω
=0
M2=Iω
=(2.5)(V/0.15)
=16.67V
I1-2=Torque x Time
=[-22.5+Ta(0.15)]5
=34.65-3V
M1+I1-2=M2
34.65-3V=16.67V
34.65=19.67V
V=1.76
V=rω
ω=1.76/0.15
ω=11.74 - Ans Wrong
freshbox said:
ω=11.74 - Ans Wrong
Hmm. I have used a somewhat different method, but got the same result. Let's see if somebody else here can point out our mistake.
freshbox said:
M2=Iω
=(2.5)(V/0.15)
=16.67V
OK.
I1-2=Torque x Time
=[-22.5+Ta(0.15)]5
=34.65-3V
Where did you get the 22.5 from? Redo that calculation.
Hi Doc Al, thanks for helping.
I got my -22.5 from the tangential force Ft=75N I used the 75 times 0.3 = 22.5 Because Tension x Radius = Torque
*Ok i think i got it, it's 300mm, 150mm diameters
There you go. :wink:
M1=Iω
=0
M2=Iω
=(2.5)(V/0.15)
=16.67V
I1-2= Torque x Time
=(TaX0.075-75X0.15)5
=17.325-1.5V
M1+I1-2=M2
17.325-1.5v=16.67v
17.325=18.17v
v=0.95
v=rω
0.95=0.15ω
ω=6.3 wrong again :cry:
freshbox said:
M2=Iω
=(2.5)(V/0.15)
=16.67V
Same problem with radius vs diameter. (Sorry I didn't spot it before.)
how come i need to take the radius of the axle and not the wheel?
You are relating ω to the speed V, which is the tangential speed of the axle edge, not the wheel edge.
Can I say the "v" that I am finding is actually the velocity of the axle. After getting the velocity of the axle, I divide by 0.075 (axle radius) is because in a compound pulley, Angular velocity are the same. I am just using the axle velocity to get ω.
Yes. V is the velocity of the falling mass, and since its cord is wrapped around the axle, V is also the tangential velocity of the axle.
The axle and wheel are attached, so they have a common ω.
Ok..I'm sorry can you help me take a look at this question part C
M1=Iω
=(3.5)(12.5)
=43.75
M2
=Iω
=3.5ω
I1-2=Torque X Time
=[(-TA)(0.2)+(TB)(0.5)]5
=-32ω+3783.5
M1+I1-2=M2
43.75-32ω+3783.5=3.5ω
3827.25=35.5ω
ω=107.80 - Wrong Answer
freshbox said:
M1=Iω
=(3.5)(12.5)
=43.75
M2
=Iω
=3.5ω
I1-2=Torque X Time
=-32ω+3783.5
Double check that last calculation.
=[(-2ω+465.5)0.2+(1327.2-12ω)0.5]5
=(-0.4ω+93.1+663.6-6ω)5
=(-6.4ω+756.7)5
=-32ω+3783.5
I'm abit blind hehe can you tell me where is wrong? :redface:
Looks to me like you left out a minus sign.
fail -.- what a mess...hehe anyway thanks for your time and help (voko too), thanks :)
I can't believe I mistook the diameters for the radii, but I did. Not just once, but multiple times when I cross-checked my results via at least three different methods. Oh well. Thanks Doc Al for pointing that out.
