In bcc lattice why XRD 100 peak is not observed ?
The absence of the XRD (100) peak in body-centered cubic (BCC) lattices is due to destructive interference caused by the arrangement of atoms within the unit cell. The structure factor, calculated using the formula S(hkl)=f{1+exp[-iπ(h+k+l)]}, reveals that S equals zero when h+k+l is an odd integer, leading to the non-observation of certain planes, including (100), (300), (111), and (221). In contrast, reflections such as (200), (110), and (222) are observed due to their even integer sums. The phase cancellation occurs because the intervening atomic planes have equal scattering power, resulting in a net zero contribution for the (100) reflection.
  • Understanding of X-ray diffraction (XRD) principles
  • Familiarity with body-centered cubic (BCC) lattice structures
  • Knowledge of structure factor calculations in crystallography
  • Basic concepts of destructive interference in wave physics
  • Study the derivation and implications of the structure factor in crystallography
  • Explore the role of atomic planes in X-ray diffraction patterns
  • Investigate the differences between BCC and face-centered cubic (FCC) lattices in XRD
  • Learn about advanced XRD techniques for analyzing crystal structures
Researchers in materials science, physicists studying crystallography, and professionals involved in X-ray diffraction analysis will benefit from this discussion.
hkazmi25
Can someone tell me that in bcc lattice why xrd 100 peak does not appear?
The planes passing through the base atoms are a/2 away from the planes passing through the planes defined by the atoms on the edge of the cell. And is only a shifted copy of the latter. Hence it will reflect x rays exactly as does one of the edge planes and you get destructive interference.
If you calculate the structure factor of the BCC lattice using:
$$S(hkl)=f{1+exp[-i\pi(h+k+l)]}$$, where f= form factor. The value o f S is zero when the exponential has the value -1, which is whenever the argument is: -i*pi* (odd integer).
So we have:
S=0 when h+k+l= odd integer
S=2f when h+k+l= even integer
So therefore the diffraction pattern does not contain these planes: (100), (300), (111), (221)
But it occurs for fx.: (200), (110), (222)
The (100) reflection occurs when reflections from the planes that bound the cubic cell differ in phase by 2*pi. In BCC there is an intervening plane of atoms, which is equal to in scattering power to the other planes. Situated between them it gives a reflection retarded in phase by pi w.r.t. the first plane, thereby cancelling the contribution from that plane. So the cancellation occurs since the planes are identical in composition.
10K
31K
