In space, an accelerating platform hit my feet from under
The discussion revolves around the effects of an accelerating platform in a space environment on a stationary observer and a ball. Participants explore concepts related to motion, inertia, and the behavior of objects under acceleration, drawing parallels to familiar scenarios such as jumping on Earth and throwing a ball on a moving train. The scope includes theoretical reasoning and conceptual clarification.
  • Some participants propose that if the observer jumps from the accelerating platform, they will land back on it due to the platform catching up, similar to how one would fall back to the ground after jumping on Earth.
  • Others argue that while on the platform, the observer will feel the weight of the ball because the force from the platform is transmitted through their arm.
  • There is a discussion about the observer's motion after jumping, with some stating that they will no longer accelerate once they leave contact with the platform, referencing Newton's first law of motion.
  • Participants compare the situation to throwing a ball upward on a moving train, noting that if the train is accelerating, the ball would not land back in the observer's hand.
  • One participant introduces the concept of liquid behavior on the platform, questioning how it would compare to Earth conditions, leading to a discussion about the Equivalence Principle and the absence of tidal forces in space.
  • Some participants clarify that while the behavior of liquid on the platform would be similar to that on Earth, there would be no visible differences due to the lack of tidal effects.
Participants generally agree on the principles of inertia and the effects of acceleration, but there are competing views regarding the specifics of motion when the observer jumps and the implications of comparing the scenario to a moving train. The discussion remains unresolved regarding the nuances of these comparisons.
Limitations include assumptions about the observer's initial conditions, the nature of the acceleration, and the absence of gravitational effects in space. The discussion does not resolve the complexities of comparing different accelerating frames of reference.
Ryan Bruch
Suppose I am stationary in space (no velocity). My body is straight. There is a stationary ball right beside me (also no velocity). Then an accelerating platform hit my feet and the ball from under. Now the ball and I are in contact with the platform constantly and accelerate at the same rate as the platform does (is this right?). It would be like I am standing on the platform.
So:
1. If I Jump from the platform, would I land back on the platform?
2. If I pick up the ball on the platform, would I feel that it is heavy?
3. If I pick up the ball from the platform and let go of it, would it land back on the platform?
1. Yes, you will. Since the platform is accelerating, it will catch back up to you, which is indistinguishable from jumping into the air and falling back to the ground.
2. Yes, because the force exerted by the platform is transferred through your arm to the ball, so you will feel its weight.
3. It would land back on the platform for the same reason that you yourself would land back on the platform after jumping.
Wait, weren't I be accelerating at the same rate as the platform does after the accelerating platform hits my feet like an elevator?
You would be accelerating at the same rate as the platform as long as you were standing on it. When you jump and are above it, you are no longer accelerating, so the platform catches up to you.
You won't keep accelerating once you stop touching the platform due to the law of inertia. That is the same reason you'd feel your own and the ball's weight when standing on the accelerating platform.
Wouldn't I be remaining in motion per Newton's first law, like how I throw
Cruz Martinez said:
You won't keep accelerating once you stop touching the platform due to your body's inertia. That is the same reason you'd feel your own and the ball's weight.
Wait, I am in space. Isn't my situation the same as this: "If I throw a ball upward while on the roof of a moving train, the ball would land right back in my hand instead of landing farther back"?
That also happens due to the law of inertia. The law of inertia says that an object on which no forces act keeps a constant velocity along a straight line, in this case the "conserved" velocity is along the direction of motion of the train since no forces act in that direction.
In the case of the accelerating platform, once you jump up and stop touching the platform, your veocity will be constant i.e. you will stop accelerating.
So if the train in my example is accelerating, the ball would not land right back in my hand? please use "correct" or "incorrect."
I suppose you mean a moving train accelerating horizontally, in that case yes the ball wouldn't land right back on your hand but on a different spot.
Okay, I understand now. The condition would be like when I am on Earth, but what about liquid water? Assuming that the platform is covered with a dorm, the temperature is optimal, and the dorm is filled with enough gas so that the pressure is enough for water to become liquid, how would it behave?
It would behave nearly identically to how it behaves on Earth. I say nearly identically because you don't have tidal forces when accelerating on a platform like you do with gravity. This is the Equivalence Principle as initially stated by Einstein: http://en.wikipedia.org/wiki/Equivalence_principle
So the original equivalence principle, as described by Einstein, concluded that free-fall and inertial motion were physically equivalent. This form of the equivalence principle can be stated as follows. An observer in a windowless room cannot distinguish between being on the surface of the Earth, and being in a spaceship in deep space accelerating at 1g. This is not strictly true, because massive bodies give rise to tidal effects (caused by variations in the strength and direction of the gravitational field) which are absent from an accelerating spaceship in deep space.
Would the difference in how it behaves be apparent (can be seen with the naked eyes)?
There would be no visible difference.
  • · Replies 30 ·
  • · Replies 25 ·
