Incline Forces: Understanding Block Movement on an Inclined Plane
  • Context: High School
  • Thread starter Thread starter ixbethxi
The discussion centers on the dynamics of a block on an inclined plane connected to a hanging mass via a massless string and pulley system. The movement direction of the block is determined by comparing the gravitational force components acting on both masses. Specifically, the force pulling the hanging mass down (m1g) and the force pulling the block down the incline (m2g sin θ) dictate the system's motion. The coefficient of friction is irrelevant in a frictionless scenario, emphasizing that the heavier mass alone does not determine movement direction.
  • Understanding of Newton's laws of motion
  • Familiarity with gravitational force and its components
  • Basic knowledge of inclined planes and trigonometric functions
  • Concept of tension in strings and pulleys
  • Study the principles of Newton's second law in multi-body systems
  • Learn about the effects of friction on inclined planes
  • Explore the concept of tension in mass-spring systems
  • Investigate the role of angles in force decomposition
Students of physics, educators teaching mechanics, and anyone interested in understanding the forces acting on objects in inclined plane scenarios.
ixbethxi
i just was wondering, when you have an incline and a box mass m sits on it attached to a massless string and a pulley and a weight hanging freely. what determines whether the block will slide up or down the ramp?
is it the horizontal weight force for the box and the force of gravity for the weight?
You have three components of force to consider: (a) the component of the weight (graviational force) parallel to the surface, (b) the component of the spring force parallel to the surface and (c) the frictional force (parallel to the surface) between the box and the incline which is proportional to the component of the box's weight normal to the surface.
All the variables matter - and don't forget the coefficient of friction...
oo i forgot to say its frictionless ;)
i mean let's say you are holding the mass on the incline still and then you let go, does the mass that's heavier determine if the mass on the incline will make it slide up or down?
Yikes! I misread your original post - thought it said spring instead of string!
No, it's not the heavier mass (alone) that determines which way it moves. Consider the limit of the incline being 0! Then no matter how massive the object on the incline is it will move toward the suspended mass.
All you have to do is compare the components of force along (parallel) to the plane.
Consider the two connected masses as a single system. Gravity pulls each end:
(1) The hanging mass end is being pulled down with a force m_1 g
(2) The mass on the incline is being pulled down the incline with a force m_2 g \sin \theta​
The greater of those two forces will determine which way the system moves.
  • · Replies 40 ·
