What is the Solution to an Inclined Plane with Pulley Problem?
The inclined plane with pulley problem involves a block of mass 20 kg and a lower pulley with an unknown mass, subjected to a net force of 100 N and an incline angle of 30 degrees. The tension in the rope (T) is derived from the equations of motion, where T = mb * g * sin(θ). The analysis reveals that the system accelerates, leading to a calculated acceleration of 2.5 m/s², which contradicts the stated answer of 5 m/s up the incline. The discrepancy suggests a need to reassess the assumptions regarding the pulley mass and the forces acting on the system.
  • Understanding of Newton's laws of motion
  • Familiarity with free-body diagrams
  • Knowledge of trigonometric functions in physics
  • Basic concepts of tension in ropes and pulleys
  • Review the derivation of tension in pulley systems
  • Study the effects of pulley mass on system dynamics
  • Learn about acceleration calculations in inclined planes
  • Explore advanced problems involving multiple pulleys and forces
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators seeking to clarify concepts related to inclined planes and pulley systems.
wy125
The included image shows the problem in its entirety. The problem is from a physics review book that I have which also includes the answer, but the explanation is beyond me. I was hoping someone could walk me through the solution.
T, the rope tension (constant throughout the rope)
mb - the mass of the block = 20 kg
mp - the mass of the lower pulley = unknown
F as the net force acting on the pulley (shown in image) = 100 N
\vartheta, the angle of incline = 30 degrees
http://img705.imageshack.us/img705/7307/pullyramp.png
Here's how I tackled this:
(1) ab = 2 ap The acceleration of the block is twice that of the pulley, since moving the pulley a distance d results in the block moving a distance 2d
A free-body diagram for the block shows that the forces pushing the block up or down the ramp are T, the rope tension pushing up, and gravity acting to move the block down the ramp.
So, taking the direction up the block to be positive we have:
(2) T - mgsin\theta = mbab
Similarly for the bottom pulley we have (taking down to be positive)
(3) 2T - F = mpap
That's as far as I get. I have 4 unknowns: T, mp, ap, ab
but only 3 equations.
Any insight or help will be appreciated.
Either they meant the pulley massless, or F being its gravitational force.
I believe in other cases the problem only solvable as a function of mass of the pulley.
So let's rewrite (2) as
T = m_{b} g sin(\theta)
I know you can solve it from here.
If we let that be the case, then the tension in the rope is balancing out the gravitational force along the ramp, which means that there is no acceleration. From the solution given, I can tell you that there is a nonzero acceleration. Have I missed something in your analysis?
Thank you for your quick reply by the way!
Either g <> 10 m/s^2, but 9.81 m/s^2, or we should figure out where the other end of the rope fixed, or something I cannot figure out.
ahh.
T=F/2=50N //it is (3) with massless pulley
Fgrav=m*g*sin(theta)=~100N (using g=10) // this is not the rope tension, just the gravitational force in the direction of rope
Facceleration=T-Fgrav =~ 50N
I'm not sure I'm following you exactly. What would you say the acceleration of the block is? 50N/20kg = 2.5 m/s? If so, that's not the stated answer. Of course the stated answer could be wrong. That is the answer i got btw the first time I tried this, but I don't think it's right to assume that T = 1/2 F because the system is accelerating. I'm not sure though -- that's why I'm here :smile:
Yes, I would say 2.5 m/s.
And I think that T=1/2F whether the block accelerates or not.
I can be wrong, of course.
What is the stated answer?
The stated answer is 5 m/s up the incline. By the way the acceleration we get from using T= 50 N results in acceleration of the block down the plane.
  • · Replies 22 ·
  • · Replies 68 ·
13K
