How Does Changing Wire Resistance Affect EMF in an AC Generator?
In an AC generator, the electromotive force (EMF) generated in the coil is not affected by the resistance of the wire used. The correct answer to the posed question is that replacing the coil wire with one of lower resistance does not increase the EMF, which is determined by the rate of change of magnetic flux. Instead, lower resistance increases the current that can flow through the circuit, as described by Ohm's Law (V = IR). Key equations include EMF = (change of flux)/time and V = IR.
  • Understanding of AC generator principles
  • Familiarity with electromagnetic induction
  • Knowledge of Ohm's Law (V = IR)
  • Basic grasp of magnetic fields and flux
  • Study the relationship between magnetic flux and EMF in AC generators
  • Learn about the effects of coil design on EMF generation
  • Explore the role of frequency in electromagnetic induction
  • Investigate the impact of wire gauge on current capacity in electrical circuits
Students studying electrical engineering, physics enthusiasts, and professionals involved in designing or analyzing AC generators and electrical circuits.
bettysuarez
This is the solution to one of the problems I came across:
In an AC generator, a coil spins in a magnetic field. Of the following choices, circle the
one that will not cause an increase in the EMF generated in the coil?
a. replacing the coil wire with one of lower resistance.
b. spinning the coil faster.
c. increasing the magnetic field.
d. increasing the number of turns of wire on the coil.
e. all of the above actions will increase the EMF.
Explain your choice.
A is the correct answer
• Lower resistance wire will not affect the EMF, which is
proportional to the rate of change of flux.
• It would however, increase the current possible.
I would like to know if EMF is the same as V = IR (Ohm's law)? Hence if resistance decreases, then EMF would decreased since V is proportional to R. Why then do the answers to this question say that resistance will not affect the induced EMF?
EMF = (change of flux)/ time
V = IR
Please see above, part 1.
Yes, it is like V = IR but you are confused about how to apply it. You can think of the induced emf as a battery the "voltage" of which depends on things like the frequency of rotation, magnetic field. etc. - there is a formula for this. Now if you take a 6 Volt battery and you hook it up to a wire, you will get a current. If now you hook up a wire of lower resistance, will the battery stop being a 6 Volt battery? No, it will just put out more current so that the product IR is constant. Same situation here.
  • · Replies 35 ·
