Increasing magnitude of the charge
The problem involves four pairs of conducting spheres with given initial charges. Participants are tasked with determining the order of increasing magnitude of charge transferred when the spheres are brought into contact, allowing charge to redistribute between them.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Some participants explore the implications of charge transfer based on the initial charges of the spheres. Others question the clarity of the problem due to missing visual information. There are attempts to derive the charge transferred using formulas and reasoning about equalization of potentials.
Participants are actively discussing the charge transfer calculations and the resulting order of magnitudes. Some have provided insights into the reasoning behind their rankings, while others express confusion and seek clarification on the correct interpretation of the problem.
There is a noted lack of clarity due to the absence of a visual reference, which some participants mention as a barrier to understanding the problem fully. Additionally, there are varying interpretations of the charge transferred based on the signs and magnitudes of the initial charges.
sophia.m
Four pairs of conducting spheres, all with the same radius, are shown in the figure, along with the net charge placed on them initially. The spheres in each pair are now brought into contact, allowing charge to transfer between them. Rank the pairs of spheres in order of increasing magnitude of the charge transferred. Indicate ties where appropriate. (Use only the symbols < and =, for example A < B = C.)
F=kq1q2/r2
F=q1+q2/2
Since I only get one chance to do this problem, I just want to make sure if my reasoning is correct or if the formula I am using correct.
What i think is:
A=-3C
B=4C
C=-2C
D= 14C
Increasing order: A<C<B<D
OR
Multplying:
A= 5C
B= 0
C=5C
D=195C
Increasing order: B<A=C<D
Any insight is appreciated.
The problem is not clear. I can't see the picture.
I have attached the picture.
Thanks for the effort.
Find the charge transferred in each case irrespective of the sign of the charge.
When the pair of charged spheres are put in contact, the charge acquired will be (q1+q2) /2 each.
Thus, for pair A, the charge transferred is - 2q, for pair B it is 4q, for pair C it is - 3q and for pair D it is q. hence, the increasing order of magnitude of charge transferred is C < A < D < B.
Am I doing it correctly?
This is not correct.
It should be
D<C<A<B
It should be
D<C=A<B
Can you explain why? I don't get it.
When kept in contact, the potentials of the spheres equalize. Since the spheres are of same radius, this would mean that the charges on the spheres equalize.
As you correctly said, the final charge on each sphere will be Q1 + Q2 /2
Charge transferred = Q1 + Q2 /2 - Q2 (Final - Initial)
Q1 - Q2 /2.
Magnitude of charge transferred
A = 2q
B = 4q
C = 3q
D = q
Decreasing order
B > C > A > D
Note: In case of A, you can either say +2q has been transferred from sphere 1 to 2 or -2q from sphere 2 to 1.
Q1 - Q2 /2.
A = 2q
B = 4q
C = 3q
D = q
Decreasing order
B > C > A > D
Thank you very much! This is correct and I get it now. :)
  • · Replies 61 ·
