Independent translational momentum
The discussion centers on the motion of a ruler on a frictionless surface after receiving a short impulse orthogonal to its long axis. It highlights that the translational velocity of the ruler is independent of the distance from the center of mass to the line of action of the impulse, while the angular velocity is dependent on that distance. The user struggles to reconcile this with the work-energy theorem, questioning how equal impulses can result in different energy distributions between translational and rotational motion. They propose that applying a force at a distance generates torque without reducing the translational impulse, which may explain the observed phenomena. The conversation also touches on the challenges of finding a practical example to demonstrate these principles.
nomism
Hi everyone,
I was watching an MIT OpenCourseWare video where the lecturer describes the problem of a rulers motion on a frictionless surface after being subjected to a 'short' impulse orthogonal to the long axis of the ruler.
(sorry as a new user I can't post images, youtube 'MIT torque lecture 21' for a problem description at 14:45 mins)
He goes on to show that the resulting translational velocity is independent of the distance between the centre of mass and the line of action of impulse
despite the fact that resulting angular velocity is dependent on that same distance.
The resultant translational direction seems obvious, but I have trouble reconciling the translational speed with the work energy theorem in the accompanying class notes (below) as I thought that equal impulses would input equal amounts of energy into the system
i.e. by my thinking rotational momentum would decrease and translational momentum would increase as the impulse is applied closer to the centre of mass
Please could someone explain this to me:smile:
W_{o,f}^{total} = \int_{o}^{f} \vec{F}_{ext}^{total}\cdot d\vec{r} + \int_{o}^{f} \vec{\tau }_{cm}^{total}\cdot d\vec{r}
<br /> = (\frac{1}{2}mV_{cm,f}^{2} + \frac{1}{2}I_{cm}\omega_{cm,f}^{2} )-<br /> (\frac{1}{2}mV_{cm,f}^{2} + \frac{1}{2}I_{cm}\omega_{cm,i}^{2} )<br />
= \Delta K_{trans} + \Delta K_{rot} = \Delta K_{total}<br />
if \tau is torque, the units don't match... I don't think that can be. What is \tau in this equation?
damnet that is tough
Thanks for the replies so far. The tau symbol is torque but I made a mistake in the second integral, it should have been with respect to the angle d theta. The units should match now.
I also forget to include the brackets to show that this is the z component of tau (i.e. the magnitude of the torque vector orthogonal to the centre of mass)
(sorry about not being able to post links but the set of notes the equation was taken from can be found by googling
'Module 27: Rigid Body Dynamics: Rotation and Translation about a Fixed Axis')
W_{o,f}^{total} = \int_{o}^{f} \vec{F}_{ext}^{total}\cdot d\vec{r} + \int_{o}^{f} (\vec{\tau }_{cm}^{total})_{z}<br /> <br /> \cdot d\theta
= \Delta K_{trans} + \Delta K_{rot} = \Delta K_{rot}<br />
Perhaps my problem is that the inputs are in fact different. I.e. a force at a distance also creates a torque and the creation of said torque does not reduce the force therefore the creation of an angular impulse does not affect the translational impulse. Does this sound reasonable to everyone?
I also can't think of an object that would impart a constant impulse kinetically. The closest I could think of is a hockey puck sliding across the surface and imparting it's kinetic energy to the ruler. However I can imagine that point of impacts distance from the centre of mass would have an effect on the pucks speed after the impact as well as the rulers.
Has anybody ever seen an experiment like this?
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
