Induced Emf in a Rectangular Coil
2 replies · 6K views
member 217843
A rectangular coil of 90 turns has dimensions of 22 x 65 cm and is located in a uniform 1 T magnetic field. In 1.7 s, the plane of the coil is rotated from a position where it makes an angle of 19° with the magnetic field to a position where it makes an angle of 64°. Calculate the average emf induced in the coil.
emf= -N*(d[itex]\Phi[/itex]/dt)
[itex]\Phi[/itex]=BAcos[itex]\vartheta[/itex]
So I calculated the change in flux to be: (B*A*cos(90-64))-(B*A*cos(90-19)=B*A*(cos(26)-cos(71))
I then calculated emf.
emf= - ((90 turns)*(1 T)*(0.22m*0.65m)*(cos(26)-cos(71)))/1.7 s = -4.34 V
This is wrong. I then entered the absolute value, which is also incorrect.
Hi SgtMousse! :smile:
looks ok :confused:
have you tried 4.3 V, since it should be two significant figures ?​
Apparently my answer was correct, even though it was marked wrong. I just checked my online homework site, and they marked it correct. They must have had it wrong before. Thanks anyway!
