Induction on a Loop Homework: 0.520Ω Square Wire
  • Thread starter Thread starter theowne
    Induction Loop
The problem involves a square loop of wire situated in the xy-plane, with a specified resistance and a magnetic field that varies with the y-coordinate and time. Participants are tasked with determining the induced current in the loop at a specific moment, using the concept of magnetic flux.
  • Participants discuss the nature of the magnetic field as a function of the y-coordinate and the implications for calculating magnetic flux. There is uncertainty about the treatment of the variable y and the necessity of integration in the flux calculation.
The discussion is ongoing, with participants seeking clarification on the definition of magnetic flux and the role of the variable y in the magnetic field. Some guidance has been provided regarding the need for integration due to the non-uniformity of the magnetic field across the loop.
Participants are working within the constraints of a homework assignment, which may limit the definitions and equations they can use. There is a focus on understanding the relationship between the magnetic field and the area of the loop.
theowne
A 20.0 cm by 20.0 cm square loop of wire lies in the xy-plane with its bottom edge on the x-axis. The resistance of the loop is 0.520 {\Omega}. A magnetic field parallel to the z-axis is given by B = 0.790 * y^2 * t, where B is in tesla, y in meters, and t in seconds. What is the size of the induced current in the loop at t = 0.550 s?
flux = A.B.cos theta
I'm having a hard time understanding this question. I see that cos theta would be one so I can use the formula A B for the flux. But what is the y^2? Is it a variable? How can I construct the d(flux) / dt? I know that the A can be pulled out, and the 0.790 as well, but I'm not sure how to treat the other two.
Yes, y is a variable. Calculating the flux involves doing an integral.
Okay but what variable is it? And why does calculating the flux involve doing an integral?
Do you understand what the xy plane is? x and y are just what they usually are. They are the x and y coordinates in the xy plane.
... why does calculating the flux involve doing an integral?
The definition of flux is an integral:
http://en.wikipedia.org/wiki/Magnetic_flux#Description
Yes, somehow I can grasp what an x y plane is, but what I meant was for clarification was what it was the y coordinate of. Is it saying the field is different at different y coordinates. And the only definition of flux we have been given to use is area cross magnetic field.
Yes, you are exactly right. However, since B is a function of y, you cannot just take out the area from the integral (the flux is not uniform over the entire square loop). You must divide the square into small area differentials dA.
Yes, as tjkubo said, for this problem you can't simply say
[tex]\Phi_B=BA\cos\theta[/tex]
but instead must use
[tex]\Phi_B=\int\vec{B}\cdot\textrm{d}\vec{A}[/tex]
How would you write [itex]\textrm{d}\vec{A}[/itex] in terms of dy in this problem?
