Induction proof that (1+1/2)^n ≥ 1+n/2
  • Thread starter Thread starter 1MileCrash
    Induction Proof
8 replies · 2K views · last reply
1MileCrash
My induction proof was really easy and simple, and people were having problems and doing substitutions and other complicated things. Normally I'd take pride in making a simpler proof but, there are really brilliant people in this class and I'm just starting to get the grasp of proofs, so it's not comforting.
Prove that for all real numbers:
[itex](1+\frac{1}{2})^{n} \geq 1 + \frac{n}{2}[/itex]
Let S be the set of natural numbers such that:
Let n = 1
[itex](1+\frac{1}{2})^{1} = 1.5[/itex]
[itex]1 + \frac{1}{2} = 1.5[/itex]
Therefore, 1 E S
Assume this is true for n = k
[itex](1+\frac{1}{2})^{k} \geq 1 + \frac{k}{2}[/itex]
Check if this implies truth for n = k + 1
Left side:
[itex](1+\frac{1}{2})^{k+1}[/itex]
[itex](1+\frac{1}{2})^{k}(1+\frac{1}{2})[/itex]
Right side:
[itex]1 + \frac{k+1}{2}[/itex]
[itex]1 + \frac{k}{2} + \frac{1}{2}[/itex]
[itex](1+\frac{1}{2})^{k}(1+\frac{1}{2}) \geq 1 + \frac{k}{2} + \frac{1}{2}[/itex]
Is a true statement because our initial assumption asserts that
Here, the greater term is multiplied by 1.5, and the lower term has .5 added to it. A number multiplied by 1.5 is always greater than the same number added to .5, except in the case of 1, in which case they are equal. Since the first term is greater than the second, and is operated on a way such that a greater result is yielded even if the two were equal,
Must be true.
Therefore S is inductive.
Therefore S = Natural Numbers.
Let n = 1
Therefore, 1 E S
Left side:
Right side:
I think you are hand-waving here. Start with the left side and show that it is >= 1 + (k + 1)/2.
Must be true.
Let n = 1
Therefore, 1 E S
Left side:
Right side:
[itex]1 + \frac{k}{2} + \frac{1}{2}[/itex][itex](1+\frac{1}{2})^{k}(1+\frac{1}{2}) \geq 1 + \frac{k}{2} + \frac{1}{2}[/itex]
Must be true.Therefore S is inductive.
The flaw is this. "A number multiplied by 1.5 is always greater than the same number added to .5, except in the case of 1, in which case they are equal." You don't have the "same number" on both sides. Just write (1+1/2)^k*(1+1/2) as (1+1/2)^k+(1+1/2)^k/2 and try that again.
Why does it matter if they aren't the same number? The left is greater than the right by induction hypothesis.
The problem is in your exposition. The language is confusing. I think you should go back to taking pride in making a simpler proof. It's not that hard. You want to show (1+1/2)^k*(1+1/2)=(1+1/2)^k+(1+1/2)^k/2>=1+k/2+1/2.
What I am saying is basically, if I assume that x is greater than y, then x + 2 is greater than y + 1.
Of course, +1 and +2 are examples of operations.
Sure, now why don't you try to clear up the original proof?
Ok, I'll take a shot. So you're telling me that I should translate the jist of it into math?
Yes, show (1+1/2)^k*(1+1/2)=(1+1/2)^k+(1+1/2)^k/2>=1+k/2+1/2. I've been repeating that for a while. It's pretty direct.
