Inductor saturation due to high dv/dt
The discussion centers on the overheating issue in a buck regulator caused by high dI/dt rather than high dv/dt. Reducing the switching frequency mitigates heat generation by decreasing core losses in the Ferrite inductor. High frequency operation induces significant eddy currents within the core material, leading to increased losses and heat. The phenomenon is attributed to core losses due to eddy currents, which are minimized by using laminated steel in transformer cores.
  • Understanding of buck regulator operation
  • Knowledge of inductor core materials, specifically Ferrite
  • Familiarity with core loss mechanisms, including eddy currents
  • Basic principles of electromagnetic induction and switching frequency effects
  • Research core loss mechanisms in Ferrite inductors
  • Learn about the impact of switching frequency on inductor performance
  • Explore the use of laminated steel in transformer cores to reduce losses
  • Investigate thermal management techniques for buck regulators
Electrical engineers, power electronics designers, and anyone involved in optimizing the thermal performance of switching regulators.
likephysics
I have a buck regulator running hot. I reduced the switching frequency and the temperature is almost normal.
The current rating of the inductor is high(2A) compared to current consumption on the board (300mA).
Why does reducing the switching frequency solve the heat problem?
Does the inductor core get hot due to high dv/dt at the switching node?
You have confirmed that it is the inductor that is getting hot?
Magnetic materials can have high losses when operating above their design frequency. What is the core material you are using? You could find out its characteristics from the manufacturers.
The Core type is Ferrite.
Yes.
It is not hi dV/Dt - but high dI/dt - or higher frequency causing higher losses. When you magnetize a core ( both a magnetic and conductive material) the expansion and contraction of the flux lines (changing flux) within the core - cause currents. The higher the frequency ( as well as harmonics) the more currents are induced and collapsed in the core material itself - yielding higher losses = heat.
Windact, can you tell me the techincal term for this loss mechanism.
Ummm.. I think just referred to as core losses due to eddy (circulating) currents. This is the reasoning for laminated steel to be used in the cores for transformers - it forces the currents into the individual laminations - smaller loops... smaller currents... smaller losses
Scroll down on this page... http://www.electronics-tutorials.ws/transformer/transformer-construction.html
