Inelastic Collision or Conversation of Energy?
The problem involves a scenario where a ball of clay is thrown at a target, which is suspended from a tree, and the two stick together upon impact. The objective is to determine the initial speed of the clay ball based on the height reached after the collision. The subject area encompasses concepts of energy conservation and momentum in inelastic collisions.
  • Mixed
  • Participants discuss the application of kinetic and potential energy equations, questioning the validity of the original poster's approach. Some participants explore the relationship between the kinetic energy of the clay before the collision and the potential energy after the collision.
There is an ongoing exploration of the problem with various interpretations of the energy conservation principles and momentum conservation. Some participants have offered guidance on how to approach the problem, while others express confusion regarding the correctness of the initial calculations.
Participants note the distinction between elastic and inelastic collisions, emphasizing that momentum is conserved during the collision, but kinetic energy is not. There is also mention of the practical implications of the calculated speeds in relation to real-world throwing capabilities.
en bloc
Leonard wants to know how fast he can throw a ball, so he hangs a 2.3 kg target on a rope from a tree. He picks up a 0.5 kg ball of clay and throws it horizontally against the target. The clay sticks to the target and the clay and the target swing up to a height of 1.5m above the initial position. How fast did Leonard throw the ball of clay?
KE+PE = KE+PE
I drew it out and thought this equation might work, but i don't think it's right for many reasons.
1/2*.5kg*v^(2)=2.8kg*9.8*1.5m
v=12.8 m/s
unrealistically high velocity.
There's no way for me to check this answer, so can someone tell me if this is right?
KE+PE = KE+PE
v=12.8 m/s
You are trying to relate the kinetic energy of the ball before the collision to the kinetic energy of the combination after collision. This collision is not elastic, so that is not correct. Any collision wher the masses stick together is inelastic.
It is correct, and not unrealistic. Think: You throw a stone and at the same time your friend starts to run. Which is faster: the stone or the man? What is the speed a man can run?
ehild
Edit: Of course it is wrong, the energy is not conserved during the collision, only after.
PeterO said:
...so that is not correct...
ehild said:
It is correct, and not unrealistic...
I'm a bit confused here. Did i get the right answer, but just with not the best approach?
And i now see how this speed isn't unrealistically high, thanks.
The answer is incorrect.
if you relate KE after collision to height reached, it shows the 2.8 kg will be traveling at between 5 and 6 m/s
Conservation of momentum will show that the 0.5 kg mass must have been traveling at a little over 30 m/s.
That is not unrerasonable, as a good baseball pitcher can throw things at up to 40 m/s. I suppose that if you "friend" was boasting about the speed at which he can throw things it may be possible, as if he couldn't throw very fast, he wouldn't be boasting.
PeterO: you are right.
ehild
That's a huge mistake on my part. The whole point of conservation of energy is that everything in the system is conserved, so i can't add new mass. Thank you!
KE+PE = KE+PE
1/2 * 2.8 kg * v^(2) = 2.8kg * g * 1.5m
v=5.42 m/s
mv+mv=(m+m)v
.5 kg * v + 0 = (2.8kg)5.42 m/s
v= 30.4 m/s
It is all right now, but never write such things that "KE+PE= KE +PE" or mv+mv=(m+m)v. They do not mean anything but "everyting is identical with itself". Use different notations and/or iindices: KE1+PE1= KE2 +PE2, m1v+m2v2=(m1+m2)u.
ehild
PeterO is right. After the collision you equate the PE to the KE of the combined target + ball of clay (2.8kg).
This gives you the velocity AFTER the collision.
MOMENTUM (not KE) is conserved during the collision so you use momentum before = momentum after to calculate the velocity of the ball of clay.
This question is an example of something called a 'ballistic pendulum'... used to determine the speed of bullets by firing into a massive block and noting how high it swings. At my school we use this technique to determine the speed of air rifle pellets!
