Inertia change through a gearbox question
  • Thread starter Thread starter mech_rocks
    Change Inertia
The discussion centers on the effect of gear ratios on the mass moment of inertia as experienced through a gearbox. Specifically, when an input shaft rotates at 540 rpm with a gearbox ratio of 2:1, the effective inertia at the input shaft is calculated as four times the inertia of the output disk. This relationship is derived from the formula for effective inertia, which states that effective inertia equals the inertia of the disk multiplied by the square of the gear ratio (I_e = r^2 I_d). The discussion also emphasizes that the gearbox does not alter the total rotational energy, which remains constant regardless of the gear configuration.
  • Understanding of mass moment of inertia in rotational dynamics
  • Familiarity with gear ratios and their impact on mechanical systems
  • Basic knowledge of rotational energy calculations
  • Concept of angular velocity and its relationship with gear systems
  • Study the principles of rotational dynamics and mass moment of inertia
  • Explore the mathematical derivation of effective inertia in gear systems
  • Learn about the conservation of energy in mechanical systems with gearboxes
  • Investigate real-world applications of gear ratios in engineering design
Mechanical engineers, physics students, and anyone involved in the design and analysis of gear systems and rotational dynamics will benefit from this discussion.
mech_rocks
Hello,
This is my first post on the webpage I hope you guys can help me out. I'm trying to understand the concept of the change of mass moment of inerita through a gearbox. I know the formula, but why does the gear ratio affect the mass moment of inertia [kg m^2]. Let's say you have a input shaft rotating at 540 rpm, a gearbox with a 2:1 ratio, and a disk on the output shaft so why is the inertia "seen" at the beginning of the input shaft equal to the inertia produced by the disk multiplied by 4 considering (effective inertia = inertia x gear ratio^2 ) ?
Maybe you could describe the physics behind this... I sure would appreciate it. Thanks!
I'm not sure this is the textbook answer, but try consider the rotational energy with and without the gearbox. First, let's apply an 10 W engine to the shaft without the gearbox for 10 seconds. The rotational energy of the disc must now be 100 J, disregarding all friction. Now insert the gear box and again apply the 10 W engine for 10 sec. The rotational energy of the disc must still be 100 J since the gearbox neither absorb nor introduce energy, and since it is the same disc with the same moment of inertia, its rotational speed must also be the same. But this means the shaft on the engine side only rotates with half angular speed (or double, depending on the "orientation" of the gearbox) compared to before and so from the engines perspective the shaft seems to have four times the moment of inertia.
So in general, if you equate the rotation energy in the two situations now using the general gearbox ratio r, you get
1/2 I_e (\omega/r)^2 = 1/2 I_d \omega^2
which after cancelling \omega implies that
I_e = r^2 I_d
Ok I kind of understand what your saying. I appreciate your time. Thanks!
  • · Replies 20 ·
12K
  • · Replies 16 ·
