Infinite decimal expansion
In summary, an infinite decimal expansion can be represented as a sum of the digits divided by the powers of 10. The supremum of this sequence of partial sums is equal to the limit of the sequence, which is the least upper bound of the terms in the sequence. This is a consequence of the monotone convergence theorem, which states that a monotonically increasing and bounded sequence has a finite limit. In our case, the sequence of partial sums is non-decreasing and bounded, so the theorem applies and the supremum is equal to the limit. This can also be seen by considering that each digit in the expansion is less than 10, so the sum of the digits divided by powers of 10 is less than 1,
kingwinner
1,270
"An infinite decimal expansion has the following meaning:
0.a1 a2 a3 a4... =
∑ ak / 10k =
k=1
sup{∑ ak / 10k : n E N}
where ∑ is the sum from k=1 to k=n."
Why is the second equality (about the supremum) true? (or why does it make sense?)
Thanks.
Here each a_k is positive, so the sequence of partial sums is increasing, and its supremum and limit are equal.
This is a consequence of the monotone convergence theorem, which states that if we have a monotonically increasing sequence of numbers (i.e. a sequence [itex](a_n)[/itex] for which [itex]a_k \leq a_{k+1}[/itex] for all k, then the sequence has a finite limit if and only if the sequence is bounded.
Remember an infinite series is nothing more than a limit of partial sums and these partial sums can be treated as a sequence. In this case, the partial sums are
[tex]s_n = \sum_{k=1}^{n} \frac{a_k}{10^k}.[/tex]
The limit [itex]\lim_{n\rightarrow \infty} s_n[/tex] if it exists, is denoted [itex]\sum_{k=1}^{\infty} \frac{a_k}{10^k}.[/itex]
Now clearly [itex](s_n)[/itex] is monotonically increasing (Why?). If it is unbounded, then the equality we are seeking is trivial. If the sequence is bounded, the monotone convergence theorem tells us that the sequence not only has a limit, but in fact this limit is the least upper bound of the terms of the sequence, which is exactly what we want.
Check out
http://en.wikipedia.org/wiki/Monotone_convergence_theorem
for more info.
Check out
for more info.
The theorem in my textbook is as follows:
if a_n is nondecreasing and bounded, then lim a_n converges to sup a_n.
But in our case, I can see that s_n is nondecreasing, but how can we prove that s_n =
n
∑ ak / 10k
k=1
is bounded?
Thanks!
n
∑ ak / 10k
k=1
is bounded?
Thanks!
It is less than [itex](a_1+1)/10[/itex].
Why?? (this is not so obvious to me...)
because [itex].0a_2a_3a_4... < .1[/itex].
Each digit is less than 10 so [itex]a_210^{-2}\le .09[/itex], [itex]a_310^{-3}\le .009[/itex], etc.
[itex]a_2 10^{-2}+ a_3 10^{-3}+ ...\le .09+ .009+ ...< .1[/itex].
1. What is an infinite decimal expansion?
An infinite decimal expansion is a way of representing a number that has an infinitely long decimal part. This means that the number cannot be expressed as a ratio of two integers, and thus has an infinite number of digits after the decimal point.
2. How is an infinite decimal expansion different from a finite decimal expansion?
A finite decimal expansion has a fixed number of digits after the decimal point, while an infinite decimal expansion has an endless number of digits after the decimal point. This means that the digits in an infinite decimal expansion never repeat or terminate, while the digits in a finite decimal expansion eventually repeat or terminate.
3. Can all numbers be expressed as infinite decimal expansions?
No, not all numbers can be expressed as infinite decimal expansions. For example, rational numbers (numbers that can be expressed as a ratio of two integers) have finite decimal expansions, while irrational numbers (numbers that cannot be expressed as a ratio of two integers) have infinite decimal expansions.
4. How does the concept of infinite decimal expansion relate to the idea of infinity?
Infinite decimal expansion is a way of representing numbers that have an infinite number of digits after the decimal point. This concept is closely related to the idea of infinity, which is the concept of something being endless or limitless. In mathematics, infinity can be approached but never reached, and this is reflected in the endless nature of infinite decimal expansions.
5. Why is the concept of infinite decimal expansion important in mathematics?
Infinite decimal expansion is important in mathematics because it allows us to work with and understand numbers that cannot be expressed as fractions or whole numbers. This is crucial in fields such as calculus, where infinitesimal quantities and continuous functions are used. Additionally, infinite decimal expansion is a fundamental concept in understanding irrational numbers and their properties.
  • Calculus
