Infinite series, power series problem
The discussion revolves around a problem related to infinite series and power series in the context of a water purification process. The original poster presents a scenario where a fraction of impurity is removed at each stage, with the fraction determined by the variable n. The goal is to analyze the implications of different values of n on the purity of the water.
  • Participants explore the series expansion for different values of n, questioning the validity of the sums derived by the original poster. There is a focus on the mathematical representation of the impurity removal process and the convergence of the series involved.
Some participants have provided guidance on how to approach the problem, suggesting the use of geometric series and clarifying the relationship between the terms of the series. There is an ongoing exploration of the implications of the sums derived for n=2 and n=3, with participants questioning assumptions and the setup of the problem.
Participants note the importance of correctly identifying the terms of the series and the distinction between the variable n in the problem and the running index of the series. There is acknowledgment of the constraints imposed by homework policies regarding the provision of complete solutions.
Liquidxlax
In a water purification process, one-nth of the impurity is removed in the first stage. In each succeeding stage, the amount of impurity removed is one-nth of that removed in the preceding stage. Show that if n=2, the water can be made a pure as you like, but if n=3, at least one-half of the impurity remains no matter how many stages are used.
may be relevant, Sn = (ao(1-rn)/(1-r))Sn-rSn = (ao-aor^n)
well i figured out the series expansion for bothSUM (1/(n^2 -n)) (sorry i couldn't figure out the text thing)n=2 gives = 1/2 + 1/6 + 1/12 + 1/20 + ...
n=3 gives = 1/6 + 1/12 + 1/20 + 1/36 + ...
I know the sum of n=2 is pretty much 1 and n=3 is pretty much 1/2. My real problem is i can't figure out how to get it into:Sn = (ao(1-rn)/(1-r))so I can differentiate to get the sum. Any help would be appreciated and thanks for helping a noob
Can you explain how you got these sums? They don't model the situation that the problem describes.
i got those sums, by finding the equation 1/(n-1) - (1/n) = 1/(n^2 - n)
This is what i did for n=2 n=2 wolfram
n=3 n=3 wolfram
Calculate the removed impurity.
At the first step, 1/n part of the impurity is removed.
In the second and every subsequent step, 1/n times the previously removed quantity is removed.
So the removed amount in k steps is
1/n +1/n^2 +1/n^3 +...1/n^k. What do you get after infinite steps?
ehild
ehild
i'm sorry but i messed up my second post, I'm not sure if you were responding to that one, but i made a mistake in my equation.
If you follow ehild's lead, you'll solve the problem pretty quickly. I'm not sure what reasoning your using to get your sums, but it's not correct.
can someone please just give me a solution, because this is apparently the easiest part of my assignment, and there are 3 questions like this, meanwhile i have completed all the apparent harder ones. If i could see one example of this sort, i should be able to figure it out.
It's against PF policy to give complete solutions. We can however, guide you towards a solution.
okay that is something i did not know.
Well can you tell me why i am wrong, because I'm really lost
all i have to work with for equations are;
Sn = (a(1-rn))/(1-r)
S = lim (n\rightarrow\infty) Sn
S = a/(1-r)
for this section, so this is what I'm assuming should help solve this problem.
I'm not sure how to find r or a, and i guess that is my major problem.
Use this ...
ehild
jgens said:
Use this ...
1/n^2 + 1/n^3 + 1/n^4 + ... + 1/n^(k-1) = Sn
1/n^3 + 1/n^4 + 1/n^5 + ... + 1/n^k-1 + 1/n^k = rSn
Sn - rSn = 1/n^3 - 1/n^k = a(1 - r^k)
a(1 - r^k) = (1/n^3)(1 - (1/n^k)) no k-3 since k is going to infinity?
Sn(1 - r) = Sn(1- (1/n))Sn = ((1/n^3)(1 - (1/n^k))) / (1 - (1/n))S = lim (k approaches infinity) Sn
S = (1/n^3)/(1 - (1/n))
Is this it? I think i got it
What happened to the term 1/n?
whoops, but if i add that it should work?
i need n=2 to infinity to ~= 1
and n=3 to infinity to ~=1/2
You, if you redo your work including that term, it should work out.
okay screw it, i'll try it your way once more, and if i don't get it... then i'll just skip it
Thanks for trying to help me, I can't help I'm border line retarded sometimes
I think you mix the "n" in the problem with the "running index" of a sequence. Forget Sn. It is the sum of the first n term of a sequence. You need the sum of infinite terms which is S=a1/(1-r) for a geometric sequence with first term a1 and ratio r.
Consider the removed amount of the impurity. Suppose its original amount is 1 in some unit. In the first step, you remove 1/n of it. In the next step, you remove the n-th part of the previously removed amount, so you remove (1/n)^2. In the third step, you remove (1/n)^3, in the k-th step, the removed amount is (1/n)^k. You continue the process endlessly, and you get the following sequence
1/n, (1/n)^2, (1/n)^3... (1/n)^k...
If n=2, it is 1/2, 1/4, 1/8, 1/16...
For n=3: 1/3, 1/9, 1/27, 1/81...
What kind of sequence is it and what is the sum of infinite terms?
This sum is the theoretical amount of impurity you can remove in infinite steps.
ehild.
you know that is what i did exactly and right after my last post i realized that, and got the problem figured out. Thank you very much for the help and not getting mad because i was so stubborn
  • · Replies 22 ·
