Initial Condition Problems with Heat Equation in Mathematica
4 replies · 8K views
mhmounty
I've been trying to work through the heat equation given in this Sous Vide cooking primer:
http://amath.colorado.edu/~baldwind/sous-vide.html
It gives a modified version of the heat equation with a shape parameter for simplification. The equations are shown below:
[PLAIN]http://amath.colorado.edu/~baldwind/heatEq3.png
When I try to put this into Mathematica, one of the initial conditions gives me the value "True". I can't figure it out for the life of me. My Mathematica input is here:
pde = {D[u[r, t],
t] == \[Alpha] (D[u[r, t], r, r] + \[Beta] D[u[r, t], r]/r),
u[r, 0] == Temp0, D[u[0, t], r] == 0,
D[u[R, t], r] == (h/k) (TempW - u[R, t])}
And this is what it spits out:
{Derivative[0, 1][r, t] ==
9.95*^-8*(Derivative[1, 0][r, t]/r +
Derivative[2, 0][r, t]), u[r, 0] == 25, True,
0 == 1250.*(60 - u[R, t])}
I've got some dummy variables in there for the alpha, beta, h, k, ... constants. I'm just not sure why this gives me "True". I know I'm completely missing something simple here. But it's been a while since I've tried to solve anything like this without finite elements.
Try "Derivative[1, 0][0,t] == 0" instead of "D[u[0, t], r] == 0". I think the latter evaluates, and the former represents (and will evaluate if it makes certain sense) but I'm not sure.
You're plugging in a value for r in your original equation for u and then differentiating with respect to r. Since there will be no terms with r in it (since you plugged 0 in for r), the resulting partial derivative will be 0. Since 0=0 is a true statement, you are getting back "true" as a result.
Try defining the derivative of u as a function and then plugging r in the derivative. However, this could also give a similar 0=0 result.
Hope this helps.
The reason it's giving your "True" is that the expression D[u[0,t],r] means "take the partial derivative of u[0,t] with respect to r". Since u[0,t] is not a function of r, its partial derivative with respect to r is 0, so this equation reduces to 0==0, which reduces to "True". As Leperous said, you can type , "Derivative[1, 0][0,t] == 0", or what is perhaps more clear: "(D[u[r, t], r] /. r -> 0) == 0", which means "take the partial derivative of u[r,t] with respect to r, and then set r=0", which is what you really want.
I am also trying to put the PDE from Douglas Baldwin's Sous Vide cooking primer into Mathematica. With the comments before (on correct notation) I was able to add the equations to Mathematica. However NDSolve is trapped by the singularity for r=0 in (1). The second term in the usual 1D heat equation is added (as far as I understand) to be able to compensate with the Beta parameter for 3D shapes such as bricks and cylinders using approriate correction factors between 0 and 2 for Beta. The condition (2) makes the singularity "better behaving" but I found no simple way to convince NDSolve not being trapped by the 1/r term in (1).
(1) D[u[r, t], t] == \[Alpha] (D[u[r, t], r, r] + \[Beta] D[u[r, t], r]/r)
(2) D[u[r, t], r] /. r -> 0) == 0
Any ideas?
