Initial value problem Euler equation
4 replies · 2K views · last reply
lisa92
Question:
Find y as a function of x:
x^2 y'' + 8 x y' - 18 y = x^8
y(1)=3, y'(1)=2
Attempted solution:
I found the general equation to be Ax^(-9)+Bx^2+Cx^8.
However when I try to solve the initial value problem for this equation I have 3 unknowns.
Welcome to PF, lisa92! :smile:
Did you substitute your solution in the DE?
If you do, you'll find you have a 3rd equation.
write
(x2D2+8 x D-18)=(xD+9)(xD-2)
or change variables u=x2 y
your general solution is extraneous check it in the equation to eliminate
That's an "Euler type" equationl. The change of variable x= ln(t) changes it to a differential equation with constant coefficients which may be simpler.
If you do not wish to do it that way, what did you get as a solution to the associated homogeneous equation?
