Innovation Aboard the Senior Bus Trip to Eilat
  • Thread starter Thread starter makaveli
    Bus
The discussion highlights a humorous observation about the distribution of ingenuity among seniors on a bus trip to Eilat, noting a parabolic increase in creativity from the front to the middle of the bus, where more engaged individuals typically sit. The peak of ingenuity is found near the teacher chaperons and programming majors, after which there is a sharp decline towards the back of the bus. This decline suggests that the credibility of ideas diminishes significantly as one moves further back, leading to a lack of firsthand knowledge about the dynamics occurring there. The conversation also touches on the age of participants, hinting at the varying levels of engagement based on proximity to the driver. Overall, the thread humorously examines how the seating arrangement influences the creative output of seniors during their trip.
makaveli
I have noticed, that a graph of ingenuity as a function of the distance from the front of a bus full of seniors on their 3-day field trip to Eilat, behaves in the following pattern: The graph Starts out at relatively low (the driver is never too bright) and climbs in a parabolic fashion to reach a certain maximum (usually where teacher chaperons and programming majors sit), after which there is an inflection point followed by a sudden, severe, almost exponential drop of the graph which now strives for zero. It is noteworthy that as the graph progresses it's credibility drops, so much as that only assumptions based on observations from afar, can be made as to what really occurs at the back of the bus, since no-one has ever ventured that far before getting sent back.
Mathematics news on Phys.org
you sit right behind the bus driver?
more or less
how old are you?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
