Input Impedance of SIMPLE Circuit
The discussion revolves around determining the input impedance of a specific circuit, with participants exploring definitions and methodologies related to input and output impedance. The conversation includes theoretical considerations, practical implications, and various approaches to calculating impedance in the context of the provided circuit.
  • One participant seeks a thorough definition of input and output impedance, questioning how to approach input impedance when voltage/current sources are present.
  • Another participant suggests flipping the circuit and shorting the voltage source to analyze it similarly to output impedance.
  • A different participant proposes converting the circuit to its Thevenin or Norton equivalent, asserting that the input impedance is 100 ohms.
  • One participant discusses the implications of ignoring the battery's internal resistance and emphasizes that real circuits may behave differently than theoretical calculations suggest, particularly in audio applications.
  • Another participant states that the input impedance is 100 ohms plus the output impedance of the battery, highlighting the need for measurements at various load currents to determine DC input impedance accurately.
Participants express differing views on how to approach the calculation of input impedance, with no consensus reached on a single method or outcome. Some emphasize theoretical calculations, while others caution about practical considerations and real-world behavior.
Participants note limitations in their approaches, such as the potential impact of hidden components in the circuit and the frequency dependence of impedance. There is also mention of the need for careful measurement techniques to accurately determine impedance values.
gayapatel
Can anyone figure out the input impedance of the circuit I have attached?
Does anyone know a THOROUGH definition of input impedance? output impedance?
Output impedance is equivalent to the thevenin impedance, which mean we turn off all voltage/current sources. But for input impedance, what if the circuit has voltage/current sources, what do we do (like the circuit I have attached)?
Still no answer :-(
Still no answer from PhysicsForums :-( :frown:
Damm.. i had a reply , but it disappeared when i clicked on your attachment ..
your first attachment , if you flip it over to the right ,and short the voltage source just like an output impedance ,what have you got??
Your second attachment looks ok ..
Convert the thevenin equivalent norton equivalent, that is a shunt resistor and a current source equal to the thevenin voltage divided by 100 ohms. The current source is supposedly infinit so doesn't affect the input impedance calculation.
Clearly the input impedance is 100 ohms.
Joe
The circuit you have shown can be looked at several ways:
(1) You can ignore the battery and replace it with an equivalent resistor representing it's internal resistance. Now you can calculate the 'impedance', and since there is no reactive component it is simply resistance with no phase shift.
(2) However, you may be misleading yourself as to how the circuit actually behaves. While the theoretical basics are good for simple circuits, real circuits rarely conform, and the results will not be anything like what you learn in class:
For example, suppose (since we are talking about impedance) that this is an audio application. Applying a D.C. voltage backwards into the output leads of an amplifier can have all kinds of disastrous effects on both the performance and the reliability of the circuit. So, although the 'impedance' we calculated is correct, the actual behaviour of the circuit could be bad. Even a small D.C. voltage applied backward might change the bias on a transistor or tube circuit, and result in the component operating in a non-linear part of its performance specs.
Likewise, one rarely applies A.C. to a drycell, so, this could be just a representation of the input circuit of an op-amp or some other useful device. This means that although there is a 'load resistance' and D.C. voltage peeking out of the input leads, there must be more attached to this circuit than actually appears. Applying an A.C. signal for instance may or may not be able to penetrate other hidden components connected to the system, like capacitors or inductors. Obviously, the circuit will not behave as assumed by the diagram.
The input impedance is 100 Ohms plus the output impedance of the battery (frequency dependent). The impedance is deltaV/DeltaI, not V/I. If you are interested in the DC Zin, you need to measure the V and I at a couple of load currents, and use the load line to give you the Z. If you are interested in the Z at a particular frequency or range of frequencies, use a signal generator through a series resistor to find deltaV/deltaI.
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 25 ·
  • · Replies 18 ·
