Insertion Loss in a (T) Two Port Network
2 replies · 5K views · last reply
agata78
Calculate the insertion loss for the network in the diagram?
20log(N)dB
N = R0 + R1 / R0 - R1
N = 141.42 + 100 / 141.42 - 100
N = 241.42 / 41.42
N = 5.82858
20log(5.82858) = 15.311
Insertion Loss = 15.31 dB
Can someone please confirm I am correct or incorrect?
  • Circuit schematic of a T-network two-port: two 100 Ohm resistors in series along the top, and a 50 Ohm resistor branching down from the junction to the bottom line.
20log(N)dB
N = (R0 + R1) / (R0 - R1)
N = (141.42 + 100) / (141.42 - 100)
N = 241.42 / 41.42
N = 5.82858
Looks good. You might use some parentheses to make the order of operations on your math clear :wink:
You probably should have explained where the R0 value came from, although it can be derived from the filter circuit itself with the assumption that it is impedance matched to the source and sink impedances.
Circuit schematic of a two-port network with two series resistors labelled R1, a shunt resistor R2 between them, load resistor R0 at port B, and labels I1, I2, V, V1, V2, Port A and Port B.
R[itex]_0{}[/itex]=[itex]\sqrt{R^2{}_1{}+2R_{1}R_{2}}[/itex]
I suppose by 'N' you mean I1/I2
