Insulator material for ion Thomson Parabola spectrometer
3 replies · 12K views
1Keenan
Hello!
I would need advice on insulator material I can use for an ion Thomson Parabola spectrometer.
I would need to use an insulating sheet of 225x600x1,5mm and a smaller sheet of 100x100x1,5mm
I found PBN having an incredible dielctric strength, but seems like it cannot be manufactured in sheets bigger that 100x200 mm with proper flatness
MIca seems to be good as well and easier to produce, but I cannot find a supplier selling it with dielectrict strenght higher than 30kV/mm. In literature it is reported something like 100kV/mm and sometimes even more.
DO you have any suggestions?
THank you in advance
Regular boron nitride or the hot pressed boron nitride is a machinable material, so the flatness is not a problem. However, 600mm is still too big, as the manufacturers don't have such a big hot presser. QS Advanced Materials have the largest boron nitride material in the market but is still at about 400mm.
Hi,
Well, I solved with a good quality PTFE, I could apply up to +/-50 on both electrodes. Then I had discharges but not through the insulator. The happened between the electrodes and a metal reinforcing pillar in the vacuum chamber.
So I made a chassis with PTFE that also reduces the gap, and the voltage
