Integral as approximation to summation
16 replies · 3K views
songoku
Show that:
$$\sum_{r=1}^n \frac{1}{n} \left(1+\frac{r}{n} \right)^{-1}\approx \int_0^1 (1+x)^{-1} dx$$
Not sure
Writing down several terms of the summation and then doing some simplifying, I get:
$$\sum_{r=1}^n \frac{1}{n} \left(1+\frac{r}{n} \right)^{-1}= \frac{1}{n+1}+\frac{1}{n+2}+\frac{1}{n+3}+...\frac{1}{2n}$$
How to change this into integral form? Thanks
songoku said:
Homework Statement:: Show that:
Relevant Equations:: Not sure
Have you tried drawing a graph? How could you simply estimate the area under a curve - any ideas?
No, I haven't. I don't know if I need to use graph. So I need to draw graph of ##y=\frac{1}{x+1}## ?
Not sure. I have drawn graph of ##y=\frac{1}{x+1}## and maybe the area under the curve from x = 0 to x = 1 can be estimated by using area of trapezium?
Thanks
songoku said:
No, I haven't. I don't know if I need to use graph. So I need to draw graph of ##y=\frac{1}{x+1}## ?Not sure. I have drawn graph of ##y=\frac{1}{x+1}## and maybe the area under the curve from x = 0 to x = 1 can be estimated by using area of trapezium?
Thanks
A trapezium is good. But, maybe you don't even need to be that clever. Take a look the terms in the sum.
I would start with the integral, how would you try to estimate the area by drawing rectangles under the graph?
Then compare that to your sum.
An alternate way is based on looking at the sum, what do you think the ##\Delta x## is in the rectangles that were used to generate it?
I have looked at the terms in the sum for a while and nothing change...
So I need to use rectangles to estimate the area under the curve and ##\Delta x## will be the width of rectangle?
Thanks
It is important to tell us what you are allowed to use. E.g. if you know
H(n)=\log(n)+\gamma+O(1/n)
then it is immediately clear.
songoku said:
I have looked at the terms in the sum for a while and nothing change...So I need to use rectangles to estimate the area under the curve and ##\Delta x## will be the width of rectangle?
Thanks
Yes, if you do this then you can get the summation on the left without much issue.
I haven't learned about that equation. The scope is high school level of integration and summation properties
I think I can get the summation from the integration. But if I want to get the integral form from summation, how to proceed from what I did previously?
$$\sum_{r=1}^n \frac{1}{n} \left(1+\frac{r}{n}\right)^{-1}=\frac{1}{n+1}+\frac{1}{n+2}+...+\frac{1}{2n}$$
or maybe I don't really need to simplify it, just leave it like this:
$$\sum_{r=1}^n \frac{1}{n} \left(1+\frac{r}{n}\right)^{-1}=\frac{1}{n} \left(\frac{n}{n+1}+\frac{n}{n+2}+...\frac{n}{n+n}\right)$$
$$=\frac{1}{n} \left( \frac{1}{1+\frac{1}{n}}+\frac{1}{1+\frac{2}{n}}+...+\frac{1}{1+\frac{n}{n}}\right)$$
I feel it will just take a little bit more work to get the integral form but I just don't know how to continue.
Thanks
Once you understand how to get the sum from the integral, you just have to work backwards. Doing this a couple times will help you build intuition about what to look for.
To take your last formula, you can write that as
$$ \frac{1}{n} f(1/n) + \frac{1}{n} f(2/n)+...$$
Where ##f(x)=\frac{1}{1+x}##. Does that suggest anything?
I think the OP isn't aware of the definition of an integral as the limit of a Riemann sum. It is almost straightforward that the sum $$\sum_{r=1}^n\frac{1}{n}(1+\frac{r}{n})^{-1}$$ is the Riemann sum of the integral $$\int_0^1(1+x)^{-1}dx$$.
But if you are not allowed to use the definition of an integral as the limit of a Riemann sum (because you might not have been taught of it as well) then perhaps @fresh_42 suggestion but you said you don't know that equation either.
That was primarily meant as a polite hint that the point
Relevant Equations:
is actually very important. It defines what we may use. It's not just you who didn't write anything there, it is unfortunately very common to write "none" or similar. As a consequence dialogues last often much longer than they should because writers and readers use different toolboxes.
Am I being too much of a curmudgeon if I suggest that maybe the template should say 'relevant 'equations or inequalities''?
Without going to get too much off topic, I think, that wouldn't change much for various reasons. I would call it actually: "background to be used" and would emphasize it a lot more than "own effort". To me it is already an effort to describe the circumstances accurately.
No I am not. I have googled it and read a little bit about it, it is really helpful
By definition, definite integral is the limit of the Riemann sum :
$$\int_a^b f(x) dx=\lim_{n \to \infty} \sum_{i=1}^n \Delta x . f(x_i)$$Let the width of rectangle be ##\Delta x## and ##\Delta x=\frac 1 n##, and the height of rectangle be ##f(x)## where ##f(x)=\frac{1}{1+x}##
To determine the upper and lower limit of integration, can it be done by using algebra or I need to get it from graph?
Relevant Equations:
Oh, sorry, I did not realize that. Personally I don't think "relevant equations" part is not important but for this question I just don't know what the relevant equations are. What I did only plug in some numbers and simplify it using basic algebra, really have no idea what other formula I have to use.
Thank you for the reminder
The upper and lower limits of integration are the effective values of x you get at the start and end of your summation. For example if ##\Delta x = 1/n## and you sum up n terms, the width of your interval must be 1.
I think I understand
Thank you very much for all the help and explanation Perok, Office_Shredder, fresh_42, Delta2
