Integral involving fractional part.
  • Context: MHB
  • Thread starter Thread starter mathisfun1
    fractional Integral
The discussion revolves around evaluating an integral involving the fractional part function, specifically in the context of two coprime integers \(a\) and \(b\). Participants explore different cases for the values of \(a\) and \(b\), and how to approach the integral through various mathematical techniques and reasoning.
  • One participant proposes dividing the unit interval into \(ab\) subintervals and expresses the fractional parts of \(ax\) and \(bx\) in terms of \(r\) and \(t\).
  • Another participant expresses confusion about the expression for the fractional part of \(ax\) and seeks clarification on the mathematical reasoning behind it.
  • A participant provides a specific example with \(a=3\) and \(b=5\) to illustrate the integral calculation, showing the steps taken to derive the fractional parts.
  • Some participants question whether there might be a simpler method to approach the integral, indicating uncertainty about the complexity of the current method.
  • One participant discusses the implications of the coprimality of \(a\) and \(b\) on the uniqueness of the pairs \((k, l)\) derived from \(r\), suggesting that each value of \(r\) corresponds to a unique pair.
  • Another participant attempts to reason why the fractional part of \(ax\) can be expressed as the sum of the fractional part of \(\frac{r}{b}\) and \(at\), while also questioning if there is a formal mathematical justification for this.
Participants express various viewpoints on the approach to the integral, with some agreeing on the method of dividing the interval and others questioning the clarity and correctness of the expressions used. The discussion remains unresolved regarding the best approach and the understanding of the fractional part function.
Participants note that their understanding of the problem is influenced by their educational background, with some expressing that the concepts discussed are beyond their current curriculum. There is also mention of the need for a deeper understanding of number theory to fully grasp the implications of the coprimality condition.
mathisfun1
I started with taking three cases,
1. a=b
since a and b are co primes, both will have to be equal to 1 and then we can easily get lhs = rhs.
2. a>b
3.a<b
I have no idea as to how to proceed for the second and third cases. Any help would be greatly appreciated.
Divide the unit interval into $ab$ subintervals $\bigl[\frac r{ab},\,\frac{r+1}{ab}\bigr]$ of length $\frac1{ab}$, for $0\leqslant r <ab.$ In each subinterval, $x = \frac r{ab} + t$ (where $0\leqslant t\leqslant \frac1{ab}$), and $ax = \frac rb + at$. Thus $\{ax\} = \bigl\{ \frac rb \bigr\} + at = \frac kb + at$ for some $k$ with $0\leqslant k <b.$ Similarly, $\{bx\} = \bigl\{ \frac ra \bigr\} + bt = \frac la + bt$ for some $l$ with $0\leqslant l <a.$
You then need to show that as $r$ goes from $0$ to $ab-1$, each of the possible values of the pair $k,\: l$ (with $0\leqslant k <b,\ 0\leqslant l <a$) occurs exactly once. To prove that, you will need to use the fact that $a$ and $b$ are relatively prime.
It will then follow that $$\begin{aligned} \int_0^1\bigl(\{ax\} - \tfrac12\bigr) \bigl(\{bx\} - \tfrac12\bigr) &= \sum_{k=0}^{b-1} \sum_{l=0}^{a-1} \int_0^{1/(ab)} \bigl(at + \tfrac kb -\tfrac12\bigr) \bigl(bt + \tfrac la -\tfrac12\bigr) dt \\ &=\int_0^{1/(ab)} \sum_{k=0}^{b-1}\bigl(at + \tfrac kb -\tfrac12\bigr) \sum_{l=0}^{a-1}\bigl(bt + \tfrac la -\tfrac12\bigr) dt \\ &= \int_0^{1/(ab)} \bigl(abt + \tfrac 12(b-1) -\tfrac12b\bigr) \bigl(abt + \tfrac 12(a-1) -\tfrac12a\bigr)dt \\ &= \int_0^{1/(ab)} \bigl(abt - \tfrac 12\bigr)^2dt \\ &= \Bigl[\tfrac1{3ab}\bigl(abt - \tfrac 12\bigr)^3 \Bigr]_0^{1/(ab)} \\ &= \tfrac1{3ab} \bigl(\tfrac18 + \tfrac18\bigr) = \tfrac1{12ab}. \end{aligned}$$
I am much thankful for your reply.
However, I am unable to understand how fractional part of ax=fractional part of r/b + at.
Also, although I am studying advanced calculus (Relative to XIIth standard, that is I am in XIIth standard but studying a bt ahead for competitive exams, we have never been taught something like this. Maybe, there's another way to do this? I am sure my maths teacher would never give us a question that he had not taught us.
There may be a simpler way to do this, but I don't see how. Maybe someone else here can help?
To get an idea of what is involved in this problem, I found it helpful to look at a simple particular case. Suppose for example that $a=3$ and $b=5$. Then to calculate the integral $$\int_0^1\bigl(\{3x\} - \tfrac12\bigr) \bigl(\{5x\} - \tfrac12\bigr)dx$$ I divided the unit interval into subintervals of length $\frac1{15}$. If you put $x = \frac r{15} + t$ and take $r=7$, say, then you are looking at the subinterval $\bigl[\frac7{15},\frac8{15}\bigr]$. In that interval, $$3x = 3\bigl(\tfrac7{15} + t\bigr) = \tfrac{21}{15} + 3t = \tfrac75 + 3t = 1 + \tfrac25 + 3t.$$ The fractional part of that is $\frac25 + 3t$ (because $0\leqslant t \leqslant \frac1{15}$ and therefore $\frac25\leqslant \frac25 + 3t \leqslant \frac35$). That illustrates why the fractional part of $ax$ is the fractional part of $\frac rb + at$.
Sorry for getting back to you so late, got caught up in school work.
Let's just say for some case, r/b=1.7 and at=0.4
then frac (ax) will be 0.7+0.4=1.1
which is not possible.
I tried a few cases taking different values of a and b and concluded that this will never happen the sum will always be less than one and thus fac(ax) can be correctly written as frac(r/b)+at.
But is there any mathematical way to say this?
Going back to my first comment above, the situation is that for each integer $r$ with $0\leqslant r<ab$, we define $\bigl\{\frac rb \bigr\} = \frac kb$ and $\bigl\{\frac ra \bigr\} = \frac la$. It then follows that $0\leqslant k<b$ and $0\leqslant l<a$. Notice that there are $ab$ possible values of $r$, and there are also $ab$ possible values for the pair $(k,l).$
Now suppose that there are two values of $r$, call them $r$ and $s$, giving rise to the same pair $(k,l)$. In other words $\bigl\{\frac rb \bigr\} =\bigl\{\frac sb \bigr\} =\frac kb$ and $\bigl\{\frac ra \bigr\} =\bigl\{\frac sa \bigr\} =\frac la$. Then the fractional part of $\frac{s-r}b$ is $0$. Therefore $s-r$ is a multiple of $b$. Similarly, $s-r$ is a multiple of $a$. But because $a$ and $b$ are coprime, that implies that $s-r$ is a multiple of $ab$. But both $r$ and $s$ are less than $ab$, so it follows that $s-r=0$, in other words $s=r$.
That says that each value of $r$ corresponds to a different value of the pair $(k,l)$. It then follows from the pigeonhole principle that each possible value of $(k,l)$ must correspond to some value of $r$.
If you know a bit of number theory, there is an alternative way to phrase the same argument. The condition $\bigl\{\frac rb \bigr\} = \frac kb$ is equivalent to $r\equiv k\pmod b$, and similarly $\bigl\{\frac ra \bigr\} = \frac la$ is equivalent to $r\equiv l\pmod a$. Because $a$ and $b$ are coprime, it then follows from the Chinese remainder theorem that $r$ is uniquely determined modulo $ab$.
