Integral of (Force * Velocity).
The discussion centers on calculating the integral of the product of force and velocity, specifically the expression \(\int(F \cdot V)dt\) for a particle moving in the x-y plane with given velocity components \(V = (64\sqrt{3}t)i + (64t - 16t^2)j\). The force \(F\) is defined as proportional to the velocity, leading to the formulation \(F = (64a\sqrt{3}t)i + (64at - 16at^2)j\) for some constant \(a\). The integral evaluates to \((4063232 a)/15\), and the discussion emphasizes the physical interpretation of this integral as representing work done, where force times distance equals work.
  • Understanding of vector calculus, specifically dot products.
  • Knowledge of kinematics, including velocity and acceleration relationships.
  • Familiarity with the concept of work in physics, defined as force times distance.
  • Basic integration techniques for polynomial expressions.
  • Study the relationship between force, mass, and acceleration using Newton's second law.
  • Learn about the physical significance of work and energy in mechanics.
  • Explore vector calculus applications in physics, particularly in motion analysis.
  • Practice solving integrals involving vector functions and their physical interpretations.
Students in physics or engineering, particularly those studying mechanics, as well as educators looking for examples of integrating force and velocity in motion problems.
Skatch
A particle moves in the x-y plane having the components of its velocity to be:
x = 64\sqrt{3}t and y = 64t - 16t^2,
and a force acting on this particle is proportional to its velocity. Find:
\int(F \cdot V)dt
from t = 0 to t = 4. Give a physical meaning to your result.
Not sure.
I'm having a hard time getting started here, because I don't know what F is. I've got:
V = (64\sqrt{3}t)i + (64t - 16t^2)j,
right? But I don't know what to dot it with inside the integral. I'm not looking for a total solution here, I'm just wondering if someone can quickly tell me what exactly F is. I should be ok from there.
If F is proportional to V, do I just set
for some unknown constant a?
Thanks.
So, if I set F equal to what I stated above, I get an answer of:
\int( F \cdot V ) dt = \int(16384 a t^2 - 2048 a t^3 + 256 a t^4)dt = (4063232 a)/15
I don't even know what to make of that...
Why would the force be proportional to the velocity?
You know (I hope) that F=m*a.
And acceleration is the derivative of velocity, isn't it?
The significance of the integral... v*dt is ds (distance). Force time distance = ?
The significance of the integral... v*dt is ds (distance). Force times distance = ?
Force times Distance equals Work
Because it's a given in the problem.
  • · Replies 25 ·
