Integral of Rational Function with Zero Result
  • Context: Graduate
  • Thread starter Thread starter StatusX
    Integral Zero
9 replies · 3K views
Homework Helper
I've just found that, for all a>0:
[tex]\int_0^\infty \frac{a (x^2 - 1)^2 - 2 x (x + a)^2}{(x + a)^3 (a x + 1)^3} dx = 0[/tex]
This can be found by brute force, but there must be a simpler way to show it.
How formal does the solution need to be? I have an idea that might work out, but I don't know if it would be exactly what you're looking for.
Id be interested to hear any thoughts you have on it.
The integrand happens to be an exact derivative of x*P(x)/Q(x) for some P and Q.
Read This First: Here are my first thoughts. The biggest problem with this is that it's not rigorous and utilizes a lot of 'hand-waving arguments' (and I'm not positive that this hand-waving is even justified here!). Another problem with it is that it's not really all that simple, so even if it can be justified, I don't think that it's much good as a solution. I think that hamster143 outlined a much better solution too. But with that qualified, here was my first thought about the problem.
Let the function [itex]f[/itex] be defined such that
[tex]f(x) = \frac{a(x^2-1)^2-2x(x+a)^2}{(x+a)^3(ax+1)^3}[/tex]​
Since [itex]f[/itex] is continuous on [itex][0,\infty)[/itex], we can apply the second fundamental theorem of calculus to find that ...
[tex]\int_0^{\infty}f(x)\mathrm{d}x = \lim_{x \to \infty}F(t) - F(0)[/tex]​
where [itex]F[/itex] is an anti-derivative of [itex]f[/itex]. Therefore, we need only find the values of these anti-derivatives. We'll go about this in an indirect way.
To find [itex]F(0)[/itex], first define the function [itex]g[/itex] such that [itex]g(x) = a(x^2-1)^2-2x(x+a)^2[/itex]. Next, note that by choosing [itex]x[/itex] small enough, we can find numbers [itex]h,k > 0[/itex] such that the following inequality holds:
[tex]h[g(x)] \leq f(x) \leq k[g(x)][/tex]​
Since it's easy to verify that [itex]G(0) = 0[/itex] (neglecting the constant) where [itex]G[/itex] is an anti-derivative of [itex]g[/itex], this suggests that the anti-derivative of [itex]f[/itex] at zero is equal to zero. Therefore, [itex]F(0) = 0[/itex].
To evaluate the term [itex]\lim_{x \to \infty}F(t)[/itex], we can note that as [itex]x[/itex] becomes arbitrarily large, [itex]f(x)[/itex] tends to something like [itex]h(x) = x^{-2}[/itex] (because the numerator is a polynomial of degree 4 and the denominator is a polynomial of degree 6). Since [itex]lim_{x \to \infty}H(x) = 0[/itex] (once again, neglecting the constant) where [itex]H[/itex] is an anti-derivative of [itex]h[/itex], this suggests that [itex]\lim_{x \to \infty}F(t) = 0[/itex].
Combining these two results, we find that ...
[tex]\int_0^{\infty}f(x)\mathrm{d}x = 0[/tex]​
hamster,
I'm not sure what you mean. Are P(x) and Q(x) supposed to be polynomials? According to mathematica, the indefininte integral contains logs, and is very complicated.
jgens,
I'm not sure I understand exactly what you're saying, but I'm skeptical of your method since you don't seem to be using the specific form of the function I gave. For example, if I changed the (ax+1) in the denominator to (ax+2), the integral would no longer be zero, but I'm not sure your argument would be any different. I think you're neglecting constants when you shouldn't be.
StatusX said:
jgens,
That's very likely. If you read the "Read This First" segment of my post, I acknowledged that.
StatusX said:
hamster,
Not according to wolfram alpha ...
http://www.wolframalpha.com/input/?i=\int+\frac{a+%28x^2+-+1%29^2+-+2+x+%28x+%2B+a%29^2}{%28x+%2B+a%29^3+%28a+x+%2B+1%29^3}+dx+
"Neglecting" the constant? :confused: You make it sound like there's One True Antiderivative which all others are just modifications of!
Of course, you can choose the constant so that G(0) = 0. And you can choose the corresponding constant so that F(0) = 0.
(it would be easier to choose F(0) directly)
Again with the One True Antiderivative thing. You can certainly choose the constant so that [itex]\lim_{x \to \infty}F(t) = 0[/itex].
Of course, there's no reason those two choices have to be consistent. :frown:
A method which doesn't require heavy developments is given in attachment.
( Typo in the attachment : remplace equation -Aa=-a by -Aa=a )
