Integral of squared error function
The discussion revolves around the evaluation of the integral of the squared error function, specifically the expression \(\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx\). Participants explore various methods of integration, including integration by parts, and share their attempts and challenges in solving the integral. The conversation also touches on related integrals involving the error function.
  • Homework-related
  • One participant requests help in solving the integral \(\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx\).
  • Another participant emphasizes the need to show working before substantial help can be provided, suggesting integration by parts as a potential method.
  • A participant expresses difficulty in obtaining analytical results for the squared error function integral, noting that applying integration by parts leads to a result of zero, which they find suspicious.
  • Another participant challenges the claim that the integral evaluates to zero, asserting that the integrand is strictly positive over the interval of integration.
  • One participant shares their workings and expresses confusion about how to express \(\sqrt{x}\) in terms of the variable used in their substitution.
  • Several participants provide hints and corrections regarding the application of integration by parts, reiterating the importance of following the correct procedure.
  • A later participant claims to have found a solution to the integral, providing a specific result, which another participant confirms as correct.
  • Additional integrals involving the error function are introduced, with participants seeking advice on their evaluation.
  • Some participants discuss the challenges of integrating expressions that involve the error function and exponential terms, noting that they encounter recurring forms that complicate the integration process.
There is no consensus on the evaluation of the integral \(\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx\), as participants express differing views on the results obtained and the methods used. Some participants agree on the need for integration by parts, while others remain uncertain about the correctness of their approaches.
Participants mention various steps in their integration processes, but there are unresolved mathematical steps and assumptions that could affect the outcomes. The discussion reflects a range of approaches and interpretations regarding the evaluation of integrals involving the error function.
This discussion may be useful for students and researchers working on integrals involving special functions, particularly the error function, as well as those interested in techniques of integration such as integration by parts.
singhofmpl
Does anybody knows how to solve the following equation?
[tex]\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx[/tex]
Please help.
regards
singhofmpl
Policy is that you must show us working before we can provide substantial help. If we don't know what you have done we done know where you got stuck. The hints I'll give you this time are: Trying integrating by parts to reduce the exponent of the error function in the integral. You can find the derivative of the error function by the Fundamental Theorem of Calculus.
Dear Sir
Your suggestion is very much correct as far as applying by parts is concerned but I'm able to get analytical results only if the integral involves only one power of the error function i.e
[tex]\int_{0}^{\infty}\mbox{erf}(\sqrt{x})\exp(-x)dx[/tex] but I'm not able to get the correcr results for the integral [tex]\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx[/tex]. If I apply by parts to the integral involving squared error function then after a long derivation finally I'm getting 0, which I' m suspicious that this solution is correct.
The answer is not zero as the integrand is strictly positive on the interval of integration. Please show me the steps you did. From the start: To reduce the power of [tex]Erf^2\sqrt{x}[/tex] in your integral, use integration by parts, letting [tex]u= \Erf^2 \sqrt{x}, dv = e^{-x} dx[/tex]. To find du, use the definition of the Error function and the Fundamental Theorem of Calculus.
After you carry that out, you should have an integral like : [tex]\int^{\infty}_0 Erf (\sqrt{x}) e^{-2x} dx[/tex]
So exp (-2x), not just exp (-x).
You can't finish there. You have to apply integration by parts again in a similar fashion, then continue from there.
Respected Sir
I'm sorry to say bet still there is problem. Please see my workings given below:
let [tex]u=\mbox{erf}^2(\sqrt{x})[/tex]
Now [tex]du=\frac{2\mbox{erf}(\sqrt{x})\exp(-x)}{\sqrt{\pi}\sqrt{x}}dx[/tex]
Now it is required to write [tex]\exp(-x)dx[/tex] in terms of [tex]du[/tex]. So
[tex]\exp(-x)dx=\frac{\sqrt{\pi}\sqrt{x}}{2\mbox{erf}(\sqrt{x})}du[/tex]
which further can be written as:
[tex]\exp(-x)dx=\frac{\sqrt{\pi}\sqrt{x}}{2\sqrt{u}}du[/tex]
but the problem is how to write [tex]\sqrt{x}[/tex] in terms of u?
Please help
Dear Sir
Thanks a lot for your prompt response. I'm really very sorry for bothering you so much. Finally I got the solution following your advice. The final answer which I'm getting is given below:
[tex]\frac{2\sqrt{2}\arctan(\frac{1}{\sqrt{2}})}{\pi}[/tex]
Please let me know whether my answer is correct.
That is correct. Don't worry about asking questions, It wasn't a bother at all.
Dear Sir
May I know your affiliation (if you don't mind) so that I can mention it while writing my report or paper?
My name is Ragib Zaman, and I am a first year student at the University of Sydney, Australia. I am studying the Bachelor of Science (Advanced Mathematics) degree.
Integral due to non-linearity of PA
Hi Ragib
While modeling the non-linear behavior of power amplifier (PA), I came to an integral of the form given below; I'm not able to figure out how to solve it.
[tex]I=\frac{A^2}{2\sigma_x^4}\int_{0}^{\infty}\frac{r^3}{r^2+A^2}\exp(\frac{j\pi}{3}\frac{r^2}{r^2+A^2}-\frac{r^2}{2\sigma_x^2})dr[/tex]
Please help me to solve it analytically.
After some initial manipulations I've managed to make it look like
[tex]ke^k \int^{\infty}_k \left(1-\frac{k}{t}\right) \frac{e^{\frac{i\pi}{3}\left(1-\frac{k}{t}\right)}}{e^t} dt[/tex]
where [tex]k = \frac{A^2}{2\sigma_x^2}[/tex]
I'm still working on reducing that further, but in the mean time you could give that form a try.
Dear Sir
kindly suggest me how find the integration of :
Hi, may I know how do you solve for [tex]\int_{0}^{\infty}\mbox{erf}(\sqrt{x})\exp(-x)dx[/tex]?
Could you detail the assignment of 'u' in each iteration of integration, and how do you get the eventual term in arctan?
Could you give me some hints on solving that because it seems to me that the integrations would loop infinitely.
I dearly need your advice. Thanks.
It's not very hard, I'm certain you can do it if you try. Integration by parts with [itex]u = erf( \sqrt{x} ), dv = e^{-x} dx[/itex]. To find du, use the fundamental theorem of calculus and the chain rule.
Regarding the original problem:
[tex] \int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx[/tex]
here is what I've got so far.
[tex] u=\mbox{erf}^2(\sqrt{x}),[/tex]
[tex] du=\frac{2\mbox{erf}(\sqrt{x})\exp(-x)}{\sqrt{\pi}\sqrt{x}}dx,[/tex]
[tex] dv = \exp(-x) dx,[/tex]
[tex] v=-\exp(-x).[/tex]
Thus, we have
[tex] \int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx = -\exp(-x)\mbox{erf}^2(\sqrt{x}) + \int_{0}^{\infty}\frac{2\mbox{erf}(\sqrt{x})\exp(-2x)}{\sqrt{\pi}\sqrt{x}}dx.[/tex]
Now suppose that I do another integration by parts with
[tex] u=\mbox{erf}(\sqrt{x}),[/tex]
[tex] du=\frac{\exp(-x)}{\sqrt{\pi}\sqrt{x}}dx,[/tex]
[tex] dv = \frac{\exp(-2x)}{\sqrt{x}} dx,[/tex]
[tex] v=\frac{\sqrt{\pi}\mbox{erf}(\sqrt{2x})}{\sqrt{2}}.[/tex]
The resultant expression becomes
[tex] \int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx = -\exp(-x)\mbox{erf}^2(\sqrt{x}) + \sqrt{2}\mbox{erf}(\sqrt{x})\mbox{erf}(\sqrt{2x}) - \frac{2\sqrt{2}}{\sqrt{\pi}}\int_{0}^{\infty}\frac{\mbox{erf}(\sqrt{2x})\exp(-x)}{\sqrt{x}}dx.[/tex]
and I'm stuck at this point where the form of [tex]\frac{\exp(x)\mbox{erf}(x)}{x}[/tex] in the integration cannot be suppressed.
I have tried to proceed with another round of integration and a similar form returns. Please kindly point me out my mistake(s). Thanks.
Sorry about the very late reply meng, I don't come on physicsforums very often anymore because of my studies. To others reading, I'm reviving this thread because I got a PM which stated this problem was in their research, so I thought I should help.
Here you go meng:
[tex]I = \int^{\infty}_0 \mbox{erf}(\sqrt{x}) e^{-x} dx[/tex]
Integrate by parts, letting [itex]u = \mbox{erf} \sqrt{x} , du = \frac{1}{2\sqrt{x}} \cdot \frac{2}{\sqrt{\pi}} e^{-x} dx[/itex] and [itex]dv = e^{-x} dx, v = - e^{-x}[/itex], where we found the derivative of u by the fundamental theorem of calculus.
This gives:
[tex]I = \left[ -\mbox{erf}\sqrt{x} e^{-x} \right]^{\infty}_0 + \int^{\infty}_0 \frac{ e^{-2x} }{ \sqrt{\pi x} } dx[/tex].
For the 1st term, as x goes to infinity, the erf term goes to a constant since [itex]\int^{\infty}_0 e^{-x^2} dx = \sqrt{\pi}/2[/itex] while the exp goes to zero, so that's zero. And when x=0, the erf term is 0 while the exp term is 1, so zero as well. So we just have the integral remaining, in which we let [itex]u = \sqrt{x}[/itex] which leaves us with
[tex]I = \frac{2}{\sqrt{\pi}} \int^{\infty}_0 e^{-2u^2} du[/tex].
Let [itex]t = \sqrt{2} u[/itex],
[tex]I = \frac{ \sqrt{2}}{\sqrt{\pi}} \int^{\infty}_0 e^{-t^2} dt = \frac{1}{\sqrt{2}}[/tex]
Thus, we have
Here's a very late reply. I find it a little easier to change variables so that the error function doesn't have the square root:
[tex] y^2 = x[/tex]
[tex] I = \int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx = 2 \int_0^\infty dy~\mbox{erf}^2(y) \exp(-y^2) y dy[/tex]
Now integrate by parts like you did, the surface term is zero
[tex] I = \frac{4}{\sqrt{\pi}} \int_0^\infty dy ~\mbox{erf}(y) \exp(-2y^2)[/tex]
At this point substitute the definition of the error function but with a change of variables so that the integration limits are constant
[tex] \mbox{erf}(y) = \frac{2}{\sqrt{\pi}}\int_0^1 d\alpha ~e^{-\alpha^2 y^2} y[/tex]
You can then change the order of integration
[tex] I = \frac{8}{\pi} \int_0^1 d\alpha \int_0^\infty dy ~ y \exp[-(2+\alpha^2)y^2]<br /> = \frac{4}{\pi} \int_0^1 d\alpha ~\frac{1}{2+\alpha^2}<br /> =\frac{2\sqrt{2}}{\pi} \tan^{-1}\frac{1}{\sqrt{2}}[/tex]
  • · Replies 27 ·
