Integral of x^2*exp(x^2) using erfc tables
  • Thread starter Thread starter ronphysics
    Integral
To integrate x^2*exp(-x^2) from 0 to infinity and from 1.5 to infinity using error function tables, the discussion emphasizes the importance of using the correct substitution and integration techniques. The integral can be approached through partial integration, leading to the expression I = (β/2)e^(-β^2) + (√π/4)erfc(β). Key equations involving the error function and its complementary function are provided to facilitate the solution. The participants clarify that the original confusion stemmed from a sign error, confirming the integral's convergence. The method outlined is effective for solving the specified integrals using error function tables.
ronphysics
Can anybody show me how to integrate x^2*exp(-x^2) between the limits 0 to infinity(symbol=00) and 1.5 to infinity with detail steps. I want this by using error function table. I know the 'multiplying integral method'. Here is what I did so far
int(0,00) x^2*exp(-x^2)
=x^2*int(0,00)exp(-x^2)-int(0,00)[2*x*int(0,00)exp(-x^2)]
=x^2(pi^0.5/2)-int(0,00)[2*x*(pi^0.5/2)] ...first term also between (0,00)
This seems to be giving 00! Where am I missing?
Thanks.
Also please show me how to do this between limits (1.5,00) with error function tables.
Did you get that right? x^2e^{x^2} is divergent, those integrals will be \infty.
Oh, I am terribly sorry. I meant x^2*exp(-x^2). Forgot the negative sign. I corrected the original post (could not correct the Sub line). Thanks.
Hmm, okay. Well what I'd do is first do a substitution, e.g.
y = x^2
Resulting in:
\frac{1}{2}\int\sqrt ye^{-y}dy
Then use partial integration which will land you with a infinite series for the indefinite integral.
For the case of:
\frac{1}{2}\int^\infty_0\sqrt ye^{-y}dy you can 'cheat' and note that it's = \frac{1}{2}\Gamma(1.5)
y = x^2
Resulting in:
For the case of:
alxm, I don't know whether your approach is correct. But its pretty straightforward with 'multiplying integration'. You can find a method somewhere on the web.
My problem is trying to use error function approach.
Hello ronphysics,
You need to use the following four equations in order to solve it the way you want. These are:
\int_0^{\infty}e^{-ax^2}dx=\frac{1}{2}\sqrt{\frac{\pi}{a}}
erf(x)=\frac{2}{\sqrt{\pi}}\int_0^{x} e^{-t^2}dt
erfc(x)=\frac{2}{\sqrt{\pi}}\int_{x}^{\infty} e^{-t^2}dt
erf(x)=1-erfc(x)
Now I will show how to obtain the general question as:
I=\int_{\beta}^{\infty}x^2e^{-x^2}dx
Afterwards you need to find for yourself the solution to your integrals, and additionally check them by using the definite numbers for \beta. If any problems occur, just post. OK, so the first step is to use partial integration. This gives:
I=\int_{\beta}^{\infty}x^2e^{-x^2}dx= -\int_{\beta}^{\infty}\frac{x}{2}d\left(e^{-x^2}\right)= -\left[\frac{x}{2}e^{-x^2}\right]_{\beta}^{\infty}+\frac{1}{2}\int_{\beta}^{\infty}e^{-x^2}dx= \frac{\beta}{2}e^{-{\beta}^2}+\frac{1}{2}erfc(\beta)\frac{\sqrt{\pi}}{2}
Therefore, after rewriting:
I=\frac{\beta}{2}e^{-{\beta}^2}+\frac{\sqrt{\pi}}{4}erfc({\beta})= \frac{\beta}{2}e^{-{\beta}^2}+\frac{\sqrt{\pi}}{4}\left(1-erf({\beta})\right)
Is this the method you were looking for?
coomast
coomast said:
Hello ronphysics,
erf(x)=1-erfc(x)
coomast
coomast,
Thanks. Thats exactly what I was looking for. My mind was stuck in separating variables as x^2 and exp(-x^2). However, the useful way to seprate is x and x*exp(-x^2). Thanks again.
Hi all,
I am trying for the following integration
∫x2 exp(a0+a1x+a2x2) dx
Please help me to find a solution.
Sivaji
