Integral: sqrt(4-x^2)*sign(x-1) dx
  • Context: Undergrad
  • Thread starter Thread starter Alexx1
    Dx Integral
The integral of the function sqrt(4-x^2) multiplied by the sign function sign(x-1) can be approached by splitting it into two cases based on the value of x. For x ≥ 1, the integral simplifies to ∫ sqrt(4-x^2) dx, while for x < 1, it becomes -∫ sqrt(4-x^2) dx. The correct evaluation of ∫ sqrt(4-x^2) dx involves trigonometric substitution, specifically using x = 2sin(t) and dx = 2cos(t) dt, leading to the integral 4∫ cos²(t) dt. The final expression simplifies to (x/2)√(4-x²).
  • Understanding of integral calculus
  • Familiarity with trigonometric identities
  • Knowledge of inverse trigonometric functions
  • Experience with substitution methods in integration
  • Study trigonometric substitution techniques in calculus
  • Learn about the double-angle identities for sine and cosine
  • Explore advanced integration techniques, including integration by parts
  • Practice solving integrals involving the square root of quadratic expressions
Students and professionals in mathematics, particularly those focusing on calculus and integral evaluation, as well as educators teaching integration techniques.
Alexx1
Can someone help me with this integral?
I've never worked with a sign funtion before, so I have absolutely no idea how to solve this integral
I would be inclined to do this as two separate integrals.
If x\ge 1, x-1\ge 0 so sng(x-1)= 1 and your integral is \int \sqrt{4-x^2}dx.
If x< 1, x-1< 0 so sgn(x-1)= -1 and your integral is -\int\sqrt{4- x^2}dx.
HallsofIvy said:
I would be inclined to do this as two separte integrals.
Thanks, but how do you solve \int \sqrt{4-x^2}dx
I've tried with: x= 2sin(t) ==> dx= 2cos(t)dt and sin(t)= x/2 ==> t= arcsin(x/2)
But then I get: 2 arcsin(x/2) + sin(2(arcsin(x/2)))
And that's wrong: the first part is correct, but the second part isn't.
What have I done wrong?
\int \sqrt{4-x^2}dx
Now, using your substitutions...
x=2sint
dx=2costdt
\int \sqrt{4-(2sint)^2}.(2costdt)
Simplifying this would give you:
4\int cos^2tdt
Did you get this? Now, you'll need to use a double-angle equality for the trigo to take the integral of this.
Mentallic said:
\int \sqrt{4-x^2}dx
x=2sint
dx=2costdt
4\int cos^2tdt
I solved it till there..
but what I did then was wrong
This is what I did:
4\int cos^2tdt
= 4((t/2)+(sin(2t)/4))
= 2t + sin (2t)
Because t= arcsin(x/2) you get:
2(arcsin(x/2)) + sin(2arcsin(x/2))
The first part is correct, the second isn't..
Mentallic said:
\int \sqrt{4-x^2}dx
x=2sint
dx=2costdt
4\int cos^2tdt
This is what I did:
4\int cos^2tdt
= 2t + sin (2t)
Not wrong, just not fully simplified. Often when you have a trig of inverse-trig you can simplify it to an algebraic expression. In this case start out be using :
\sin(2 \theta) = 2 \sin(\theta) \, \cos(\theta)
and see if you can simplify it from there.
BTW. Since you know it's "wrong" then I assume that you have the correct answer at hand and you know that this second part should simplify to :
\frac{x}{2} \, \sqrt{4-x^2}
It does. :)
It does. :)
Thank you very much!
But.. when I do this (t= arcsin(x/2)) I get:
sin(2t)
= 2 sin(t) cos (t)
= 2 sin(arcsin(x/2)) cos(arcsin(x/2)
= 2 (x/2) (sqrt(1-(x/2)))
Do I have to bring the 2 into the sqrt to get sqrt(4-x^2)?
sin(2t)
= 2 sin(t) cos (t)
You are missing the square in 2(x/2)\sqrt{1- (x/2)^2}.
You don't have to but putting that 2 inside the square root will give you the form of the answer above:
(x/2)\sqrt{4(1- x^2/4)}= (x/2)\sqrt{4- x^2}
Thank you!
  • · Replies 31 ·
  • · Replies 19 ·
